mididocs:seq:chords [2014/09/25 03:09] borfo |
mididocs:seq:chords [2016/03/22 21:19] admin ↷ Links adapted because of a move operation |
Line 1: | Line 1: | ||
- | **[[mididocs:index|MIDIdocs]]** | + | This page is obsolete, most information has been incorporated into the [[mididocs:seq:beginners_guide:start|Beginner's Guide]] |
- | ======Chords====== | + | |
- | [[http://midibox.org/forums/topic/19067-mididocs-seqv4-chords-discussion-thread/|Forum Discussion Thread]] - for comments, corrections, or questions about this article | + | |
- | When you initialize a track as a CHORD track type, the first parameter layer is a special "chord" layer. Data on this layer is represented as upper or lower case letters with an octave offset. The letters on CHORD layers are not related to note names - For example, an "A" is not necessarily an A chord. | ||
- | {{chord.gif}} | ||
- | When not transposed, the chords in a chord layer are all C chord variants. You can play other chords by transposing the chord track (either by external keyboard, or with a loopback bus track). For example: To play a D major chord, choose an "A" chord type, and send a D note to transpose the chord track. To play an E minor chord, choose an "a" chord type, and send an E to transpose the chord track. | ||
- | If you're not up on your music theory, you might want to use [[forceScale|Force-To-Scale]] when transposing chords to ensure that your results are always in key. | ||
- | When not transposed, the 32 chord letters correspond to the following chords: | ||
- | * **A-C:** Major I, Major II, Major III (transposed variants) | ||
- | * **A:** C Major (Root position) (notes: C E G) | ||
- | * **B:** C Major (1st inversion) (notes: E G C) | ||
- | * **C:** C Major (2nd inversion) (notes: G C E) | ||
- | * **D-F:** Root note, 3rd note, 5th note (single notes) | ||
- | * **D:** note: C | ||
- | * **E:** note: E | ||
- | * **F:** note: G | ||
- | * **G,H:** Root+3rd, Root+5th | ||
- | * **G:** notes: C E | ||
- | * **H:** notes: C G | ||
- | * **I-N:** Maj6, Maj7, Maj8, Maj9, Maj10, Maj12 (4-note chords) | ||
- | * **I:** C Maj6 (notes: C E G A) | ||
- | * **J:** C Maj7 (notes: C E G B) | ||
- | * **K:** C Maj8 (notes: C E G C) | ||
- | * **L:** C Maj9 (notes: C E G D) | ||
- | * **M:** C Maj10 (notes: C G C E) | ||
- | * **N:** C Maj12 (notes: C G C G) | ||
- | * **O-P:** Sus4 and Maj+ | ||
- | * **O:** C Sus4 (notes: C F G) | ||
- | * **P:** C Maj+ (notes: C E G#) | ||
- | * **a-c:** Minor I, Minor II, Minor III (transposed variants) | ||
- | * **a:** C Minor (Root position) (notes: C D# G) | ||
- | * **b:** C Minor (1st inversion) (notes: D# G C) | ||
- | * **c:** C Minor (2nd inversion) (notes: G C D#) | ||
- | * **d-f:** Root note, 3rd Min. note, 5th note (single notes) | ||
- | * **d:** note: C | ||
- | * **e:** note: D# | ||
- | * **f:** note: G | ||
- | * **g,h:** Root+3rd min, Root+5th | ||
- | * **g:** notes: C D# | ||
- | * **h:** notes: C G | ||
- | * **i-n:** Min6, Min7, Min8, Min9, Min10, Min12 (4-note chords) | ||
- | * **i:** C Min6 (notes: C D# G A) | ||
- | * **j:** C Min7 (notes: C D# G B) | ||
- | * **k:** C Min8 (notes: C D# G C) | ||
- | * **l:** C Min9 (notes: C D# G D) | ||
- | * **m:** C Min10 (notes: C G C E) | ||
- | * **n:** C Min12 (notes: C G C F#) | ||
- | * **o-p:** CoG and Min+ | ||
- | * **o:** CoG (notes: C F G) | ||
- | * **p:** C Min+ (notes: C E G#) | ||
- | ====Adding Notes to Chord Tracks==== | ||
- | Chord tracks can have additional NOTE [[layersintro|Parameter Layers]]. You can enter notes on these layers, and they will be played along with any chords on that step. | ||
- | ====Resources==== | ||
- | * [[http://www.ucapps.de/midibox_seq_manual_tut3.html|Tutorial on how to use chords, transposition, and loopback to play a chord progression]] - with audio examples. | ||
- | * [[http://midibox.org/forums/topic/19026-chordnote-handling-relative-to-selected-scale/?p=166212|Forum Thread discussing how chord tracks and transposition/force-to-scale works on the SEQ]] |
