mios_c_simulator_-_debugger [2007/01/17 12:47] stryd_one |
mios_c_simulator_-_debugger [2007/10/06 12:14] stryd_one |
Line 1: | Line 1: | ||
AC-Sim: AudioCommander's Simulator for MIOS Applications. This has been named after it's creator but hopefully all MIDIBoxers will feel free to contribute to and share their code. | AC-Sim: AudioCommander's Simulator for MIOS Applications. This has been named after it's creator but hopefully all MIDIBoxers will feel free to contribute to and share their code. | ||
+ | Please see [[mios_c_simulator_-_debugger#Release_and_Developer_Notes]] for version info.\\ | ||
+ | If you add something make sure, you note it here, otherwise your submissions might get overwritten! | ||
Line 18: | Line 21: | ||
Line 25: | Line 27: | ||
^ Source ^ Contents ^ Notes ^ | ^ Source ^ Contents ^ Notes ^ | ||
- | | **ACSim_console** | | Adaption required! | | + | | **ACSim_console** (Console based input, main runloop) | | Adaption required! | |
| [[acsim_console_h|ACSim_console.h]] | Hardware related defines | Change #defines to reflect your settings | | | [[acsim_console_h|ACSim_console.h]] | Hardware related defines | Change #defines to reflect your settings | | ||
| [[acsim_console_c|ACSim_console.c]] | Main runloop | Add additional c. source-files here | | | [[acsim_console_c|ACSim_console.c]] | Main runloop | Add additional c. source-files here | | ||
- | | **ACSim_toolbox** | | //No changes required// | | + | | **ACSim_mios** (MIOS Emulation) | | //No changes required// | |
- | | [[acsim_toolbox_h|ACSim_toolbox.h]] | Hexview config | //No changes required// | | + | |
- | | [[acsim_toolbox_c|ACSim_toolbox.c]] | Helpers like random generators and hex-view | //No changes required// | | + | |
- | | **ACSim_mios** | | //No changes required// | | + | |
| [[acsim_mios_h|ACSim_mios.h]] | pic18f452.h typedefs and global vars | //No changes required// | | | [[acsim_mios_h|ACSim_mios.h]] | pic18f452.h typedefs and global vars | //No changes required// | | ||
| [[acsim_mios_c|ACSim_mios.c]] | MIOS functions for simulation | //No changes required// | | | [[acsim_mios_c|ACSim_mios.c]] | MIOS functions for simulation | //No changes required// | | ||
+ | | **ACSim_tools** (Tools & Helpers) | | //No changes required// | | ||
+ | | [[acsim_toolbox_h|ACSim_toolbox.h]] | Hexview config | //No changes required// | | ||
+ | | [[acsim_toolbox_c|ACSim_toolbox.c]] | Helpers like random generators and hex-view | //No changes required// | | ||
+ | | [[acmididefines|ACMidiDefines.h]] | Midi Defintion listing | //No changes required// | | ||
+ | You can download the files in a {{acsim.zip|.zip file here}}. If you make any updates, please send them to sstryd_one and he will update the zip for you. | ||
To implement the ACSim files into your applicaton, you just have to follow the [[mios_c_simulator_-_debugger#setup_guide|setup guide]] to: | To implement the ACSim files into your applicaton, you just have to follow the [[mios_c_simulator_-_debugger#setup_guide|setup guide]] to: | ||
Line 51: | Line 55: | ||
* MIOS_Init() | * MIOS_Init() | ||
* MIOS_LCD_Init() | * MIOS_LCD_Init() | ||
- | * MIOS_Timer() is polled each runloop() | + | * MIOS_Tick() is polled each runloop() |
+ | * MIOS_Timer() is polled each runloop() when a timer has been set | ||
For detailed step-by-step instructions see //Setup Guide// below! | For detailed step-by-step instructions see //Setup Guide// below! | ||
Line 68: | Line 73: | ||
*(**e**)ncoder(**++**)/(**- - -**) | *(**e**)ncoder(**++**)/(**- - -**) | ||
*(**a**)(//pin,value//) | *(**a**)(//pin,value//) | ||
+ | *(**b**)yte(//system realtime number//) | ||
*(**j**)umper(//pin//) | *(**j**)umper(//pin//) | ||
*(**p**)rogramChange(//PRG,{store}//) | *(**p**)rogramChange(//PRG,{store}//) | ||
Line 85: | Line 91: | ||
* Type "m176,20,100" to send a Midi Controller Change #20 on CH1 (176) with a value of 100 -> calls MPROC_NotifyReceivedEvent | * Type "m176,20,100" to send a Midi Controller Change #20 on CH1 (176) with a value of 100 -> calls MPROC_NotifyReceivedEvent | ||
* Type "m192,10" to send a Program Change request for PRG 10 -> calls MPROC_NotifyReceivedEvent(..) | * Type "m192,10" to send a Program Change request for PRG 10 -> calls MPROC_NotifyReceivedEvent(..) | ||
+ | * Type "b248" to send a single System Realtime byte (248 is MIDI_CLOCK) | ||
====== Setup Guide ====== | ====== Setup Guide ====== | ||
Line 94: | Line 104: | ||
[[how_to_use_xcode2_as_ide_on_a_mac|Setup Guide for XCode on Mac]]\\ | [[how_to_use_xcode2_as_ide_on_a_mac|Setup Guide for XCode on Mac]]\\ | ||
- | [[stryd_one_codeblocks|Setup Guide for Code::Blocks on PC]]\\ | + | [[windows_toolchain_codeblocks|Extend your toolchain with Code::Blocks and GDB]] (Don't forget [[windows_toolchain_core|Part 1]][[windows_toolchain_asm_acsim| & 2]]!)\\ |
[[application_development|General Development Info]] | [[application_development|General Development Info]] | ||
Line 101: | Line 111: | ||
- | Then proceed by configuring your main.h and main.c files: | + | Then proceed by configuring your main.c, and .h files: |
- | == main.h == | ||
- | * you need to add some lines at the bottom of your main.h - this is because debug_mios.c calls "DISPLAY_Init()" as MIOS would. Because of the #ifdef statement this does not change your syx-project code! | ||
- | <code c> | ||
- | #ifdef _DEBUG_C | ||
- | // export functions that are called from within debug_mios.c | ||
- | // (e.g. to trigger DISPLAY_Init after sending...) | ||
- | extern void DISPLAY_Init(void); | ||
- | #endif | ||
- | </code> | ||
== main.c == | == main.c == | ||
- | Minor modifications are required to your MIOS Application's main.c and main.h files. | + | Minor modifications are required to your MIOS Application's main.c file. |
- | * You need to add some lines at the top of your main.c - this is to avoid including headers for the PIC/MIOS Core module, when compiling a console app for debugging. Because of the #ifndef statement this does not change your syx-project code, so your app will compile as normal for the PIC! | + | * You need to edit some lines at the top of your main.c - this is to avoid including headers for the PIC/MIOS Core module, when compiling a console app for debugging. Because of the #ifndef statement this does not change your syx-project code, so your app will compile as normal for the PIC! |
Before: | Before: | ||
Line 135: | Line 132: | ||
#endif | #endif | ||
</code> | </code> | ||
+ | == main.h == | ||
+ | * you need to add some lines at the bottom of your main.h, or, if you don't have one, main.c - this is because debug_mios.c calls "DISPLAY_Init()" as MIOS would. Because of the #ifdef statement this does not change your syx-project code! | ||
+ | <code c> | ||
+ | #ifdef _DEBUG_C | ||
+ | // export functions that are called from within debug_mios.c | ||
+ | // (e.g. to trigger DISPLAY_Init after sending...) | ||
+ | extern void DISPLAY_Init(void); | ||
+ | #endif | ||
+ | </code> | ||
== ACSim_console.h == | == ACSim_console.h == | ||
- | * Choose your OS | + | * Choose your OS by enusering that only one of these lines is remarked (the one you DON'T want!) |
+ | * //#define _DEBUG_OS_WIN | ||
+ | * //#define _DEBUG_OS_MAC | ||
* Select the LCD-Size | * Select the LCD-Size | ||
* Set the number of AIN-Lines | * Set the number of AIN-Lines | ||
Line 149: | Line 164: | ||
== ACSim_console.c == | == ACSim_console.c == | ||
- | If you have more than just main.c, you have to add the source to these .c files (c only, no headers, else you will get a bunch of compile errors. | + | If you have more than just main.c, you have to add the source to these .c files (c only, no headers, else you will get a bunch of compile errors. See the comments in the ACSim_console.c file for details. |
- | == ACSim_mios & ACSim_Toolbox == | + | == ACSim_mios & ACSim_Toolbox incl. ACMidiDefines == |
These files don't need to be changed, just add them to your project. | These files don't need to be changed, just add them to your project. | ||
Line 171: | Line 186: | ||
- | Update: Updated to v0.0.4, now works on MS Windows with GCC (and probably other compilers too) // stryd_one // | + | Update 0.0.4: now works on MS Windows with GCC (and probably other compilers too) // stryd_one // |
+ | Update 0.0.5: splitted code to seperate wiki-documents, code cleanup, cleaned namespaces, added MIOS_ICC and MIOS_HLP functions // audiocommander // | ||
+ | Update 0.0.5-r1: Splitted ACSim_toolbox into header and source // audiocommander // | ||
- | Update: Updated to v0.0.5, splitted code to seperate wiki-documents, code cleanup, cleaned namespaces, added MIOS_ICC and MIOS_HLP functions // audiocommander // | + | Update 0.0.5-r2: 2007 January 17 improved MIOS_IIC for SpeakJet debugging // audiocommander // |
- | Update: Splitted ACSim_toolbox into header and source // audiocommander // | + | Update 0.0.6: 2007 January 21 added MIDI-Merger, INTCONbits (MIDI-Clock support) // audiocommander // |
- | Update: 2007 January 17 improved MIOS_IIC for SpeakJet debugging // audiocommander // | + | Update 0.0.7: 2007 January 26 added MIDI-Debug Messages, improved Timer() calls, added Tick() calls // audiocommander // |
