mios_studio
Differences
mios_studio [2008/10/22 11:22] – nebula | mios_studio [2010/09/27 20:04] – removed obsolete documentation about MIOS Studio 1 admin | ||
Line 1: | Line 1: | ||
- | ====== MIOS Studio ====== | ||
- | The original documentation can be found under [[http:// | + | Documentation about MIOS Studio |
- | MIOS Studio was started by Wilba in November 2003, and later taken over by Adam King. | + | [[http:// |
- | It is a java-based, platform-independent MIDI processing environment, | ||
- | Adam hasn't finished all of his plans yet, therefore only a precompiled | ||
- | binary package is available. It can be downloaded from the [[http:// | ||
- | He is interested in your inputs - how is it working, are there any problems, | ||
- | does the user interface need improvements, | ||
- | ===== Installation Instructions ===== | ||
- | So far the program has been tested with Windows 98, 2000 and XP. In theory, it should also run on Vista, Linux and Mac but the old saying proves true, "write once, debug everywhere" | ||
- | ==== Windows Installation Instructions ==== | ||
- | To run MIOS Studio you will need the Java Runtime, at least version 1.5 installed. If you do not have it, you will need to go to the Sun site [[http:// | ||
- | Once Java is installed, all you will need to do is download MIOS Studio from the [[http:// | ||
- | In Windows, you should be able to just double click on the .jar file to open the program. To start from a command line (or setup a shortcut), you can use the command | ||
- | java -jar < | ||
- | to open MIOS Studio. | ||
- | As an added utility, a cutdown version with just a keyboard controller, MIDI routing/ | ||
- | java -cp < | ||
- | ==== Mac Installation Instructions ==== | ||
- | MIOS Studio 7.5 Beta functions correctly under Mac OS X 10.4 (and, likely, onward). | ||
- | You will first need to install either // | ||
- | The " | ||
- | If you intend to continue to use Mandolane, don't forget to pay for it! It's the only way to bring MIOS Studio to your Mac, therefore it just saved your bacon! | ||
- | Also don't forget to edit this page if you discover compatibility issues, or have anything to add. | ||
- | ==== Linux Installation Instructions ==== | ||
- | Linux MIDI support is supposed to be working, but I have had many problems - possibly due to an older kernel and ALSA drivers. If anyone can test on a newer version of Linux (with Java 1.5 installed) it would be greatly appreciated. | ||
- | For Debian and distributions based on it, such as Ubuntu; you need to install three packages. | ||
- | sudo apt-get install sun-java5-bin sun-java5-jre libgcj7-awt | ||
- | Once this is done, you can start MIOS Studio by typing: | ||
- | java -jar MIOSStudio(version).jar | ||
- | =====Using MIOS Studio===== | ||
- | Below are examples of some of the main features of MIOS Studio. For further details, click on the links to go to the relevent section of the [[http:// | ||
- | ==== MIDI Routing ==== | ||
- | [[http:// | ||
- | **The readable port (MIDI IN of your interface) has to be routed to the MIOS Studio In Port, and the writable port (MIDI OUT of your interface) has to be routed to the MIOS Studio OUT Port:** | ||
- | {{http:// | ||
- | ==== HEX Upload ==== | ||
- | [[http:// | ||
- | {{http:// | ||
- | You should **ALWAYS** use 'Smart Mode', and enable 'Wait for Upload Request', | ||
- | ==== Other Tools ==== | ||
- | [[http:// | ||
- | {{http:// | ||
- | [[http:// | ||
- | {{http:// | ||
- | [[http:// | ||
- | {{http:// | ||
- | It's also possible to read and write the memory. | ||
- | [[http:// | ||
- | {{http:// | ||
- | [[http:// | ||
- | {{http:// | ||
- | [[http:// | ||
- | {{http:// |
mios_studio.txt · Last modified: 2011/10/08 22:13 by gslug
