pad_4_4 [2016/08/10 22:53] latigid_on [BOM v1.1] |
pad_4_4 [2016/08/10 23:03] latigid_on [Assembly] |
Line 62: | Line 62: | ||
If using shrouded headers, ensure the notch points on the same side as the pin 1 designator. | If using shrouded headers, ensure the notch points on the same side as the pin 1 designator. | ||
==== Interconnections ==== | ==== Interconnections ==== | ||
- | * J2 normally connects to J4B (I2C) | + | * J2 normally connects to Core J4B (I2C) |
* J3 carries the WS2812B chain for additional modules | * J3 carries the WS2812B chain for additional modules | ||
* J4 connects to a DIN header | * J4 connects to a DIN header | ||
Line 72: | Line 71: | ||
- | ==== License ==== | + | ===== License ===== |
Currently the design is (c) 2016 antilog devices with all rights reserved; all documentation is CC BY-NC-SA 3.0. | Currently the design is (c) 2016 antilog devices with all rights reserved; all documentation is CC BY-NC-SA 3.0. |
