pedal_box
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
pedal_box [2010/04/13 08:29] – durisian | pedal_box [2014/01/19 10:08] – shuriken | ||
Line 192: | Line 192: | ||
[[http:// | [[http:// | ||
- | Help can be found in the [[http://www.midibox.org/ | + | Help can be found in the [[http:// |
Line 412: | Line 412: | ||
<box 46% left round bluedark|Device Bankstick Downloads> | <box 46% left round bluedark|Device Bankstick Downloads> | ||
- | [[http:// | + | {{:mcrozier:v-amp.zip|Behringer V-Amp Series}} |
<box 46% left round|PC Editor> | <box 46% left round|PC Editor> | ||
- | [[http:// | + | {{:mcrozier: |
Please note the editor requires a minimum of WinXP with .Net 3.5 \\ | Please note the editor requires a minimum of WinXP with .Net 3.5 \\ | ||
<box 98% round|Docs> | <box 98% round|Docs> | ||
Line 452: | Line 451: | ||
- | Please report bugs in the [[http://www.midibox.org/ | + | Please report bugs in the [[http:// |
Line 611: | Line 610: | ||
The shift register of the 1st digit (the one's display) must be defined in pbx_config.h \\ | The shift register of the 1st digit (the one's display) must be defined in pbx_config.h \\ | ||
The second digit (ten' | The second digit (ten' | ||
+ | If only 1 digit is used, and bank goes higher than 9. The dot will light up to let you know that ' | ||
In place of LED digits. A 2x20 LCD Display can be used (instead of 2x16). The last 4 charcters of each line are used for bank display. This will only happen when DIGITS_CONNECTED = 0 in pbx_config.h. | In place of LED digits. A 2x20 LCD Display can be used (instead of 2x16). The last 4 charcters of each line are used for bank display. This will only happen when DIGITS_CONNECTED = 0 in pbx_config.h. | ||
Line 685: | Line 686: | ||
{{mcrozier: | {{mcrozier: | ||
You know you want to build it! | You know you want to build it! | ||
pedal_box.txt · Last modified: 2014/01/19 10:10 by shuriken
