phatline
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
phatline [2016/08/24 01:41] – [Phatline] phatline | phatline [2023/04/02 19:52] – [Project list] phatline | ||
Line 4: | Line 4: | ||
DIY-man in everything I am really interested\\ | DIY-man in everything I am really interested\\ | ||
Europe, Austria - Katsdorf , born in 1983\\ | Europe, Austria - Katsdorf , born in 1983\\ | ||
+ | take a break and listen [[https:// | ||
When I want to make a track, or do a gig, i want total control of parameters, and I want to move & save them all.\\ | When I want to make a track, or do a gig, i want total control of parameters, and I want to move & save them all.\\ | ||
Line 13: | Line 15: | ||
then I wanted to go to almost latency free technologies- so again i come to Midibox where i take the knowledge from the MAX-Groovebox and put it into C-codes, and that was new again, and it is still... [[triggermatrix|Triggermatrix]] was born.\\ | then I wanted to go to almost latency free technologies- so again i come to Midibox where i take the knowledge from the MAX-Groovebox and put it into C-codes, and that was new again, and it is still... [[triggermatrix|Triggermatrix]] was born.\\ | ||
- | @ the moment i took a year free, beeing more interesting | + | @ the moment, i am still a free artist - years of freedom, and December is always the time of year to invent new Music-Machines! I love the dark time in year... but also the summmer: where the music machines will be used... and other plans accour - of a more biological in nature livestyle, anastasia, tom brown jr, earthships, glasshouses, |
=====Project list===== | =====Project list===== | ||
+ | //Actual// | ||
+ | **Triggermatrix 5 aka TM5:** | ||
+ | * [[Triggermatrix5]] Overview and Build Tutorial\\ | ||
+ | * [[TM5-GateInput]] Levelshifter 5V>3V and Preamp for Gate/ | ||
+ | * [[TM5-codeblock]] Menuesection\\ | ||
+ | * [[TM5-Gate-Board]] 3,5 Jack Boards for 16 + 16 Gates\\ | ||
+ | * [[TM5-DinDoutGate]] Module for UI and Gates for\\ | ||
+ | * [[Core4Disc]] CoreBoard for STM32F407VGT6 Discovery Boards, with some onboard Peripheral\\ | ||
+ | * [[Core4DiscMidiEx]] Midi-Expansion Board for Core4Disc\\ | ||
+ | * [[DisplayDriver-SMD]] Display Driver for 18x SSD1306 7Pin Displays\\ | ||
+ | * [[BLM16x16V2]] 16x16 Button Led Matrix | ||
+ | * [[TM5-Housing]] Alle Files, and Description for Panels - so you can source it on your own\\ | ||
+ | **Open PAD** | ||
+ | * [[OpenPAD]] First concept off using the MPD 226 Pads and Foil with custom PCB, with MIOS!\\ | ||
+ | * [[DoutX2DinX1]] SMD board with free Production Files- can be used for other project too.\\ | ||
+ | * [[OpenPAD-Codeblock]] Buttons and Encoder Board - in combination with [[DoutX2DinX1]] Free Files!\\ | ||
+ | * [[Core4OpenPAD]] A STM32F407VGT6 based Board - Pick and Place\\ | ||
+ | **DAW-Ableton** | ||
+ | * [[DAW-Ableton]] A DAW Controller for Ableton with a bunch of M4L sysex...\\ | ||
+ | * [[DAW-BTN]] 3+3 LED Buttons, a PCB tu build a DAW-Controller\\ | ||
+ | * [[DAW-Encoder-Display]] SSD1306 and Encoders, a PCB to build a DAW-Controller (scaleable)\\ | ||
- | //Currently on work @11-07-2016// | + | // paused projects: |
- | * [[mb-euroland|MidiBox EuRoland]] | + | * [[MSQ-CC-LRE-V2]] Optimized for Eurorack, now with Displays - at the moment hardcodet for Nord Drum2\\ |
- | * [[TriggerMatrix]] | + | * [[Euro-Aout-NG-Connector-Board]] --- a Breakoutboard for the whell known Aout-NG-Dac-Board. |
+ | * [[Euro-Midi-IO]] --- a Eurorack Sized 2IN 2THRU 2OUT Midi-IO-Board, | ||
+ | * [[LoopA-EuroRack-Panel]] --- a Eurorack Frontpanl + Breakoutoboard for Midiphy LoopA | ||
+ | * [[LRE-OLED-Bar]] --- PCB to hold SSD1306 Screens above fairlightiii´s[[mb-lre8x2cs_pcb]] inside Eurorack | ||
+ | * [[SRIO-Router]] --- 1 UI, routed to 8 Cores | ||
+ | * [[LRE5-LCD2]] --- 5 Ledrings, 5 Encoders, 2 1306er LCDs, 1 Button on 10x10cm (pick and place) | ||
+ | * [[STELLAx4]] --- 4x TIA Chips fired with a STM32F4, on a 10x10cm Board | ||
+ | * [[Envelope-Follower-Bissel-based]] | ||
+ | * [[scale-explorer]] | ||
+ | * [[XYZ-IR-Controller]] | ||
+ | * [[CV1]] --- EuroRack - CV-Recorder - Looper, LFO, and ENV-Generator | ||
+ | * [[CC-Looper]] 4CH * 128CC * 512 Step --- Midi Control Change Looper | ||
+ | * [[TriggerMatrix]] Specific UI | ||
+ | * [[mb-digiroland|MidiBox EuRoland]] | ||
* [[easy_cv]] | * [[easy_cv]] | ||
* FILTERBOX --- easy cv will move to filterbox | * FILTERBOX --- easy cv will move to filterbox | ||
+ | * [[mnmlCore]] | ||
+ | * [[KongaTrigga]] --- Konga > Electret Mic > Preamp > Schmitt Trigger > uC > MidiNotes | ||
+ | * [[CoilWinder]] Coil Winder, Mios-Based Tesla-Coil Winding machine | ||
+ | * [[TriggerMatrix4]] TMV4 | ||
+ | * [[TriggerMatrix]] TMV3 | ||
+ | * [[clock2audio2clock]] convert Midiclock 2 Audio, record this audio, play this audio convert 2 Midiclok, for Multitrack Audio Studios without Midi, in order to overdub a track that need to be in Midi-Clock-Sync, | ||
+ | * [[MSQ-CC-BCR]] some kind of a synth programmer, but with CC-Motionsequencer, | ||
+ | * [[MSQ-CC-LRE]] V1 same as MSQ-CC-BCR but, newer, faster, better... also hardcodet for Nord Drum2 | ||
=====Contact===== | =====Contact===== | ||
triggermatrix@gmail.com\\ | triggermatrix@gmail.com\\ | ||
+ | paradies@siglgut.at\\ | ||
+ | [[http:// | ||
[[http:// | [[http:// | ||
[[https:// | [[https:// | ||
Line 30: | Line 79: | ||
- | [[https:// |
phatline.txt · Last modified: 2023/09/07 19:50 by phatline
