phatline
Differences
phatline [2020/12/31 01:32] – [Phatline] phatline | phatline [2022/01/12 23:10] – [Project list] phatline | ||
Line 18: | Line 18: | ||
=====Project list===== | =====Project list===== | ||
- | //Currently on work @06-02-2020// | + | //Currently on work @08-01-2022// |
+ | * [[LRE-OLED-Bar]] --- PCB to hold SSD1306 Screens above fairlightiii´s[[mb-lre8x2cs_pcb]] inside Eurorack | ||
+ | * [[SRIO-Router]] --- 1 UI, routed to 8 Cores | ||
+ | * [[LRE5-LCD2]] --- 5 Ledrings, 5 Encoders, 2 1306er LCDs, 1 Button on 10x10cm (pick and place) | ||
+ | * [[STELLAx4]] --- 4x TIA Chips fired with a STM32F4, on a 10x10cm Board | ||
+ | * [[Envelope-Follower-Bissel-based]] | ||
* [[scale-explorer]] | * [[scale-explorer]] | ||
* [[XYZ-IR-Controller]] | * [[XYZ-IR-Controller]] | ||
Line 31: | Line 37: | ||
+ | * [[TriggerMatrix4]] TMV4 | ||
* [[TriggerMatrix]] TMV3 | * [[TriggerMatrix]] TMV3 | ||
* [[clock2audio2clock]] convert Midiclock 2 Audio, record this audio, play this audio convert 2 Midiclok, for Multitrack Audio Studios without Midi, in order to overdub a track that need to be in Midi-Clock-Sync, | * [[clock2audio2clock]] convert Midiclock 2 Audio, record this audio, play this audio convert 2 Midiclok, for Multitrack Audio Studios without Midi, in order to overdub a track that need to be in Midi-Clock-Sync, |
phatline.txt · Last modified: 2023/09/07 19:50 by phatline
