phatline [2022/12/25 02:56] phatline [Project list] |
phatline [2023/01/12 22:22] phatline |
Line 18: | Line 18: | ||
=====Project list===== | =====Project list===== | ||
- | //Currently on work @21-12-2022// | + | //Actual// |
- | * [[Core4Disc]]CoreBoard for STM32F407VGT6 Discovery Boards, with some onboard Peripheral\\ | + | **Triggermatrix 5 aka TM5:** |
- | * [[Triggermatrix5]]\\ | + | * [[Triggermatrix5]] Overview and Build Tutorial\\ |
- | * [[DisplayDriver-SMD]]Display Driver for 18x SSD1306 7Pin Displays[[Triggermatrix5]] | + | * [[TM5-GateInput]] Levelshifter 5V>3V and Preamp for Gate/Trigger-Input\\ |
- | * [[BLM16x16V2]] 16x16 Button Led Matrix, made for [[Triggermatrix5]] | + | * [[TM5-codeblock]] Menuesection\\ |
+ | * [[TM5-Gate-Board]] 3,5 Jack Boards for 16 + 16 Gates\\ | ||
+ | * [[TM5-DinDoutGate]] Module for UI and Gates for\\ | ||
+ | * [[Core4Disc]] CoreBoard for STM32F407VGT6 Discovery Boards, with some onboard Peripheral\\ | ||
+ | * [[Core4DiscMidiEx]] Midi-Expansion Board for Core4Disc\\ | ||
+ | * [[DisplayDriver-SMD]] Display Driver for 18x SSD1306 7Pin Displays\\ | ||
+ | * [[BLM16x16V2]] 16x16 Button Led Matrix | ||
+ | * [[TM5-Housing]] Alle Files, and Description for Panels - so you can source it on your own\\ | ||
+ | **Open PAD** | ||
+ | * [[OpenPAD]] First concept off using the MPD 226 Pads and Foil with custom PCB, with MIOS!\\ | ||
+ | * [[DoutX2DinX1]] SMD board with free Production Files- can be used for other project too.\\ | ||
+ | * [[OpenPAD-Codeblock]] Buttons and Encoder Board - in combination with [[DoutX2DinX1]] Free Files!\\ | ||
+ | * [[Core4OpenPAD]] A STM32F407VGT6 based Board - Pick and Place\\ | ||
+ | // paused projects: // | ||
* [[DAW-BTN]] 3+3 LED Buttons, a PCB tu build a DAW-Controller | * [[DAW-BTN]] 3+3 LED Buttons, a PCB tu build a DAW-Controller | ||
* [[DAW-Encoder-Display]] SSD1306 and Encoders, a PCB to build a DAW-Controller (scaleable) | * [[DAW-Encoder-Display]] SSD1306 and Encoders, a PCB to build a DAW-Controller (scaleable) |
