phatline [2022/12/29 10:52] phatline [Project list] |
phatline [2023/01/20 00:14] phatline |
Line 29: | Line 29: | ||
* [[DisplayDriver-SMD]] Display Driver for 18x SSD1306 7Pin Displays\\ | * [[DisplayDriver-SMD]] Display Driver for 18x SSD1306 7Pin Displays\\ | ||
* [[BLM16x16V2]] 16x16 Button Led Matrix | * [[BLM16x16V2]] 16x16 Button Led Matrix | ||
+ | * [[TM5-Housing]] Alle Files, and Description for Panels - so you can source it on your own\\ | ||
+ | **Open PAD** | ||
+ | * [[OpenPAD]] First concept off using the MPD 226 Pads and Foil with custom PCB, with MIOS!\\ | ||
+ | * [[DoutX2DinX1]] SMD board with free Production Files- can be used for other project too.\\ | ||
+ | * [[OpenPAD-Codeblock]] Buttons and Encoder Board - in combination with [[DoutX2DinX1]] Free Files!\\ | ||
+ | * [[Core4OpenPAD]] A STM32F407VGT6 based Board - Pick and Place\\ | ||
+ | **DAW-Ableton** | ||
+ | * [[DAW-Ableton]] A DAW Controller for Ableton with a bunch of M4L sysex...\\ | ||
+ | * [[DAW-BTN]] 3+3 LED Buttons, a PCB tu build a DAW-Controller\\ | ||
+ | * [[DAW-Encoder-Display]] SSD1306 and Encoders, a PCB to build a DAW-Controller (scaleable)\\ | ||
// paused projects: // | // paused projects: // | ||
- | * [[DAW-BTN]] 3+3 LED Buttons, a PCB tu build a DAW-Controller | ||
- | * [[DAW-Encoder-Display]] SSD1306 and Encoders, a PCB to build a DAW-Controller (scaleable) | ||
* [[MSQ-CC-LRE-V2]] Optimized for Eurorack, now with Displays - at the moment hardcodet for Nord Drum2\\ | * [[MSQ-CC-LRE-V2]] Optimized for Eurorack, now with Displays - at the moment hardcodet for Nord Drum2\\ | ||
* [[Euro-Aout-NG-Connector-Board]] --- a Breakoutboard for the whell known Aout-NG-Dac-Board. | * [[Euro-Aout-NG-Connector-Board]] --- a Breakoutboard for the whell known Aout-NG-Dac-Board. |
