pic_programmer_modules [2006/05/01 16:57] moebius |
pic_programmer_modules [2011/08/29 08:05] maloneypark |
Line 1: | Line 1: | ||
- | PIC Burner or JDM modules are used to program Bootstrap loader to the PIC. It's also possible to buy PIC with pre-burned bootstrap loader. (recommended) | + | \\ |
+ | PIC Burner or JDM modules are used to program the Bootstrap loader to the PIC. It's also possible to buy PIC with pre-burned bootstrap loader. (recommended, see [[where_to_order_components]]) | ||
+ | After having burnt the 1st Level Bootloader, MIOS is able to accept application-uploads by SysEx (Midi). | ||
- | * [[http://www.ucapps.de/mbhp_jdm.html|JDM Module]] (expired!) <sup>uCApps</sup> | + | * [[pic_burner|PIC Burner]] |
- | * [[http://www.ucapps.de/mbhp_burner.html|PIC Burner]] <sup>uCApps</sup> | + | * [[jdm|JDM Module]] (expired!) but also working Module to Burn all PICs (16F877,16F88,18F452 & 18F4620) |
+ | * [[http://www.ucapps.de/mbhp_iic_midi.html]] contains a section, where a PIC18->PIC16 Adapter for PIC Burner is described | ||
* [[HowTo program a PIC]] | * [[HowTo program a PIC]] | ||
* [[PIC Brennen|Hilfe beim PIC Brennen]] | * [[PIC Brennen|Hilfe beim PIC Brennen]] | ||
* [[How to select a PIC ID Header]] | * [[How to select a PIC ID Header]] | ||
+ | * [[http://cvresumewritingservices.org/|resume writing]] | ||
