pinheader
Differences
pinheader [2016/06/07 12:34] – psykhaze | pinheader [2016/06/07 18:08] – psykhaze | ||
Line 1: | Line 1: | ||
====== Pinheader ====== | ====== Pinheader ====== | ||
A pinheader is a basic connector to plug things on your PCB without having them soldered. | A pinheader is a basic connector to plug things on your PCB without having them soldered. | ||
- | It can be single or dual row. The usual pitch, aka the distance between 2 pins is 2,54mm. | + | It can be **single or dual row** (SIL-DIL). The usual pitch, aka the distance between 2 pins is 2,54mm. |
+ | A pin header is designed to be splitted that you can have only the number of pins required to solder. |
pinheader.txt · Last modified: 2016/07/11 00:00 by psykhaze
