pinheader [2016/06/07 15:23] psykhaze |
pinheader [2016/06/07 18:08] psykhaze |
Line 1: | Line 1: | ||
====== Pinheader ====== | ====== Pinheader ====== | ||
- | {{ ::neonking:pinheader.png?direct&600 |}} | + | {{ ::neonking:pinheader.png?direct&500 |}} |
A pinheader is a basic connector to plug things on your PCB without having them soldered. | A pinheader is a basic connector to plug things on your PCB without having them soldered. | ||
It can be **single or dual row** (SIL-DIL). The usual pitch, aka the distance between 2 pins is 2,54mm. | It can be **single or dual row** (SIL-DIL). The usual pitch, aka the distance between 2 pins is 2,54mm. | ||
+ | A pin header is designed to be splitted that you can have only the number of pins required to solder. |
