pinheader [2016/06/07 18:07] psykhaze |
pinheader [2016/07/11 00:00] psykhaze |
Line 1: | Line 1: | ||
====== Pinheader ====== | ====== Pinheader ====== | ||
- | {{ ::neonking:pinheader.png?direct&500 |}} | + | {{ ::neonking:pinheader.png?direct&400|}} |
A pinheader is a basic connector to plug things on your PCB without having them soldered. | A pinheader is a basic connector to plug things on your PCB without having them soldered. | ||
- | It can be **single or dual row** (SIL-DIL). The usual pitch, aka the distance between 2 pins is 2,54mm. | + | |
- | A pin header is designed to be splitted that you can hav only the number of pins required to solder. | + | It can be **single or dual row** (SIL-DIL). |
+ | The usual pitch, aka the distance between 2 pins is **__2,54mm__**. | ||
+ | A pin header is designed to be splitted that you can have only the number of pins required to solder. |
