Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionNext revisionBoth sides next revision |
questionable [2009/08/16 22:42] – 68.164.135.32 | questionable [2009/10/06 11:50] – partial formatting fix (something with the italics not closed properly) WickedBlade |
{{:finalwiring-1.jpg|}} | {{:finalwiring-1.jpg|}} |
This shot shows all of the panel components wired and ready to attach to the modules. | This shot shows all of the panel components wired and ready to attach to the modules.// |
===== Problems I encountered: ===== | ===== Problems I encountered: ===== |
**The LCD DIM Pot doesn't work:** For whatever reason, the pot I have on the core that is supposed to dim the backlight doesn't work. I don't really care though, as the LCD is at a good level, and I don't think I'll need to change it. | **The LCD DIM Pot doesn't work:** For whatever reason, the pot I have on the core that is supposed to dim the backlight doesn't work. I don't really care though, as the LCD is at a good level, and I don't think I'll need to change it. |
| **Trouble Doing Sysex Transfers via Vmidibox64:** I wanted to customize the button/LED behavior to act as toggled inputs instead of simple on/off (meaning 1 press turns LED on, 2nd press turns LED off), as well as change the default fader/pot labels (Reverb, Chorus, etc) to labels that matched the functions on my box. It seems to be easily done via Serge's Vmidibox64 program, but every time I would then try to do the sysex dump to the midibox, the LCD would start showing bizarre characters, or shift over a few characters. Weird stuff. Eventually, I used Midi-Ox and the mk_syx perl script to create the Sysex file and upload it, which worked perfectly. Details of this process can be found here: http://www.ucapps.de/howto_tools_mbsyx.html |
===== Additional Thoughts and Considerations: ===== | ===== Additional Thoughts and Considerations: ===== |
