scratchcontroller
Differences
scratchcontroller [2016/07/04 01:12] – [Photos] psykhaze | scratchcontroller [2016/07/04 01:44] – [Assembly] psykhaze | ||
Line 13: | Line 13: | ||
* A smooth, reliable, high quality crossfader with curve control. | * A smooth, reliable, high quality crossfader with curve control. | ||
- | **[[http:// | + | **[[http:// |
===== Design ===== | ===== Design ===== | ||
==== Crossfader ==== | ==== Crossfader ==== | ||
- | The crossfader is the simplest part of the project. | + | The crossfader is the simplest part of the project. |
- | | + | For example : **[[http:// |
- | * [[http:// | + | |
- | The analogue ins of the PIC mean the fader can be used with no additional circuitry. Hooray! | ||
==== Jog Wheel ==== | ==== Jog Wheel ==== | ||
Line 82: | Line 78: | ||
- | Notes/Hints : | + | **Notes/Hints :** |
* There should be washers between the nuts and the scratch wheel. | * There should be washers between the nuts and the scratch wheel. |
scratchcontroller.txt · Last modified: 2016/07/04 01:46 by psykhaze
