seq_v4_plus
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
seq_v4_plus [2017/09/13 19:03] – [Module Interconnection and Assembly] latigid_on | seq_v4_plus [2018/08/20 21:15] – [Required modules] latigid_on | ||
Line 1: | Line 1: | ||
====== SEQ V4+ ====== | ====== SEQ V4+ ====== | ||
+ | //Image credit: TK. Prototype version.// | ||
Around November 2016 I embarked upon a new version of the SEQ v4. Some initial concepts had an integrated 16*4 BLM included, but the idea was refined to something simpler. | Around November 2016 I embarked upon a new version of the SEQ v4. Some initial concepts had an integrated 16*4 BLM included, but the idea was refined to something simpler. | ||
Line 11: | Line 14: | ||
The following components are intended to comprise a full SEQ V4+: | The following components are intended to comprise a full SEQ V4+: | ||
- | * [[SEQV4plus_le_MEC|le MEC]] (*2 required) | + | * [[SEQV4plus_le_mec|le mec]] (*2 required) |
* [[SEQV4plus_Beat_LED|Beat LED]] (optional but recommended) | * [[SEQV4plus_Beat_LED|Beat LED]] (optional but recommended) | ||
* [[SEQV4plus_ENC-PLATE|ENC-PLATE]] (*2 required) | * [[SEQV4plus_ENC-PLATE|ENC-PLATE]] (*2 required) | ||
Line 24: | Line 27: | ||
* [[wcore_line-transmit|line-transmit]] | * [[wcore_line-transmit|line-transmit]] | ||
* in effect there is space for a DB-25 expansion port, so alternative options are possible. | * in effect there is space for a DB-25 expansion port, so alternative options are possible. | ||
+ | ===== Draft BOM ===== | ||
+ | Please find the parts to order below; no responsibility will be taken for incorrect parts or values! You can always contact the developer for suggestions of any corrections. Parts to order from the suggested suppliers should be coloured in green, as the price can vary a lot. Europeans benefit from free shipping (and likely with VAT/customs pre-paid) by ordering over 50 EUR from Mouser. | ||
===== Matching case ===== | ===== Matching case ===== |
seq_v4_plus.txt · Last modified: 2018/12/18 09:33 by latigid_on
