seqv4plus_le_mec [2017/10/09 21:19] latigid_on [v1.0] |
seqv4plus_le_mec [2017/11/20 18:05] latigid_on [BOM v1.0] |
Line 16: | Line 16: | ||
^Resistors^^^^^^^^^^ | ^Resistors^^^^^^^^^^ | ||
| |1 |wire link |THT |R17 | | | | | | | | |1 |wire link |THT |R17 | | | | | | | ||
- | | |18 |47R 5% |THT |RJ1-9 | | | | |see instructions | | + | | |16 |47R 5% |THT |RJ1-8 | | | | |see instructions | |
- | | |8 |100-220R 5% |THT or 1206 |SJ1-8 | | | | |see instructions | | + | | |10 |100-220R 5% |THT or 1206 |SJ1-8, RJ9 | | | | |see instructions | |
| |16 |1k 5% |THT |R1-16 | | | | | | | | |16 |1k 5% |THT |R1-16 | | | | | | | ||
+ | | |8 |10k 5% |1206 |R18-25 | | | | |near NPN transistors | | ||
^Resistor networks^^^^^^^^^^ | ^Resistor networks^^^^^^^^^^ | ||
| |3 |9*10k |SIP10 |RN1-3 | | | | |bussed network, __not__ 5 pairs of resistors | | | |3 |9*10k |SIP10 |RN1-3 | | | | |bussed network, __not__ 5 pairs of resistors | | ||
Line 26: | Line 27: | ||
^Diodes^^^^^^^^^^ | ^Diodes^^^^^^^^^^ | ||
| |24 |1N4148 |THT | | | | | | | | | |24 |1N4148 |THT | | | | | | | | ||
+ | | |24 |BAT54|SOT-23 | |512-BAT54 |BAT 54 SMD | | |(for prototypes, stack on top of BC818 transistors | | ||
^LEDs^^^^^^^^^^ | ^LEDs^^^^^^^^^^ | ||
| |16 |RGB flat |superflux | | | | |ELV: 68-10 94 64 |see instructions| | | |16 |RGB flat |superflux | | | | |ELV: 68-10 94 64 |see instructions| |
