stm32f4_module
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
stm32f4_module [2016/08/03 17:36] – [Introduction] psykhaze | stm32f4_module [2016/08/03 17:48] – [Features] psykhaze | ||
Line 15: | Line 15: | ||
* Very useful integrated peripherals for MIDI and Synthesizer applications, | * Very useful integrated peripherals for MIDI and Synthesizer applications, | ||
* The USB OTG (Micro-USB) socket supports **MIDI Host**, which means that it's possible to connect a USB MIDI Keyboard or Synth | * The USB OTG (Micro-USB) socket supports **MIDI Host**, which means that it's possible to connect a USB MIDI Keyboard or Synth | ||
- | * The on-board Audio DAC predestinates this module for synthesizer projects - it could even be used standalone without the MBHP_CORE_STM32F4 breakout board for this purpose. | + | |
* in distance to STM32F103RE, | * in distance to STM32F103RE, | ||
- | * It's easy to interface external components like SD Cards and MBHP_ETH | + | |
* STM32F4xx is supplied at 3V, but **5V tolerant inputs allow to access all existing MBHP modules without additional hardware**. | * STM32F4xx is supplied at 3V, but **5V tolerant inputs allow to access all existing MBHP modules without additional hardware**. | ||
* **Performance boost by using the DMA** for background operations, such as scanning DIN/DOUT modules, analog inputs but also I2S transfers (Audio Output) w/o loading the CPU | * **Performance boost by using the DMA** for background operations, such as scanning DIN/DOUT modules, analog inputs but also I2S transfers (Audio Output) w/o loading the CPU | ||
Line 26: | Line 26: | ||
===== Known Issues ===== | ===== Known Issues ===== | ||
- | * ADCs cannot be supplied at 5V, 3.3V is the limit, and the STM32F4DISCOVERY board uses an even lower voltage (3V). This decreases the signal/ | + | |
- | * Pin mapping suboptimal in some cases. E.g., the outputs of the integrated DAC (not the on-board Audio-DAC) overlay SPI1 pins. However, one DAC channel has been freed up with the small drawback that SPI1 can't be used in slave mode. | + | |
* The IO pins of the SDIO peripheral (high speed SD Card access) conflicts with the on-board Audio DAC, so that it can't be used. | * The IO pins of the SDIO peripheral (high speed SD Card access) conflicts with the on-board Audio DAC, so that it can't be used. | ||
- | * Although the chip contains 6 UARTs, only 4 RX and TX pins could be found for MIDI IN/OUT. IN3/OUT3 even have to use two different UARTs. | + | * Although the chip contains 6 UARTs, |
* No on-board Ethernet PHY | * No on-board Ethernet PHY | ||
- | * No PHY for the second USB peripheral - would be nice to have, e.g. to support USB MIDI device and host (e.g. for the connection of a USB MIDI Keyboard), USB Memory Sticks or even a USB harddisk in parallel. | + | |
- | ===== Parts List ===== | + | ===== Parts List / Schematic===== |
See [[stm32f4_core_board_parts_list|Core32 Parts List]] | See [[stm32f4_core_board_parts_list|Core32 Parts List]] | ||
+ | * {{http:// | ||
===== Inputs/ | ===== Inputs/ | ||
Line 43: | Line 45: | ||
===== Buy Places ===== | ===== Buy Places ===== | ||
+ | * [[http:// | ||
+ | * [[https:// | ||
+ | * [[http:// |
stm32f4_module.txt · Last modified: 2016/08/03 17:48 by psykhaze
