stryd_one_preparation [2006/06/12 05:42] stryd_one |
stryd_one_preparation [2016/06/05 22:56] psykhaze |
Line 1: | Line 1: | ||
- | ====== Preparation ====== | ||
- | ====== Tools ====== | ||
- | ===== Software ===== | ||
==== Software Development==== | ==== Software Development==== | ||
- | [[stryd_one_mplab|MPLab IDE]]\\ | ||
- | [[stryd_one_codeblocks|CodeBlocks C IDE]]\\ | ||
- | [[stryd_one_gputils|GPUtils]]\\ | ||
- | [[stryd_one_sdcc|SDCC]]\\ | ||
- | [[stryd_one_activeperl|ActiveState ActivePerl]]\\ | ||
- | [[stryd_one_ultraedit|UltraEdit32]] - Not a freebie, but worth the money IMO, and I don't say that often.\\ | ||
- | + | Please see the toolchain setup docs for info on the software I use: [[application_development]] | |
- | ==== Hardware Development ==== | + | |
- | [[stryd_one_eagle|Eagle Layout Editor]]\\ | + | |
- | [[stryd_one_eagle3d|Eagle 3D]]\\ | + | |
- | [[stryd_one_povray|POV-Ray]]\\ | + | |
- | [[stryd_one_schaeffer_fpd|Schaeffer Front Panel Designer]]\\ | + | |
- | [[stryd_one_sketchup|Google SketchUp 3D ]]\\ | + | |
- | [[stryd_one_inkscape|InkScape Vector Graphics Editor]]\\ | + | |
- | [[stryd_one_electronicsassistant|http://www.electronics2000.co.uk/ Electronics Assistant Calculators]]\\ | + | |
- | [[stryd_one_MiscEl|http://www.miscel.dk/ MiscEl Miscellaneous Electronics Calculators]]\\ | + | |
- | [[stryd_one_SwCAD|Linear Technology Corporation LTspice/SwitcherCAD III Circuit Emulator]]\\ | + | |
- | ==== MIDIBox Control ==== | + | |
- | [[stryd_one_jre|Sun Java RE]]\\ | + | |
- | [[stryd_one_jsynthlib|JSynthLib]]\\ | + | |
- | [[stryd_one_mios_studio|MIOS Studio]]\\ | + | |
- | ==== Misc ==== | + | |
- | [[stryd_one_acrobat|Adobe Acrobat Reader]]\\ | + | |
- | [[stryd_one_pdfcreator|PDF Creator]]\\ | + | |
- | [[stryd_one_msie|Microsoft Internet Explorer]]\\ | + | |
- | [[stryd_one_strokeit|StrokeIt Mouse Gesture Recognition]]\\ | + | |
- | ==== WIKI ==== | + | |
- | [[stryd_one_msoffice|Microsoft Office]]\\ | + | |
- | [[stryd_one_word2doku|MSWord to DokuWiki Converter]]\\ | + | |
===== Hardware ===== | ===== Hardware ===== | ||
- | ==== Safety ==== | + | //This part has moved to other sections// |
- | * Workbench - Protect your house, have a proper work area | + | |
- | * Safety Glasses - Protect your sense of sight | + | |
- | * Ear plugs/Ear Muffs - Protect your sense of hearing | + | |
- | * Face mask - Protect your lungs | + | |
- | * Fire Extinguisher - Don't let your soldering iron start a fire you can't put out | + | |
- | * Fire Blanket - As above | + | |
- | * Storage Unit - Put your tools and components somewhere safe | + | |
- | * Small Plastic Cup - Somewhere to put things temporarily. Don't leave your kit lying around. | + | |
- | * Soldering Smoke Absorber/Ventilator - MMmmm, Lead smoke. Mmmmm, Cancer. Mmmm, Insanity. Mmm.... I think not. | + | |
- | ==== Soldering ==== | + | |
- | * Soldering Iron - Temperature controlled | + | |
- | * Soldering Iron Stand - Put it where it belongs | + | |
- | * Soldering Iron Tip Cleaner - Take care of your tools | + | |
- | * Solder - Good quality solder for good quality joints, 63/37 Eutectic | + | |
- | * Tinning Block - for taking care of soldering iron tips | + | |
- | * PCB Holders - Make soldering easier and cleaner | + | |
- | * Desoldering Braid - For removing chips from inferior boards, to insert in you MBHP ;) | + | |
- | * Desoldering Pump - As above | + | |
- | * Breadboard - Prototyping | + | |
- | ==== Electronics ==== | + | |
- | * Multimeter - For testing circuitry. RS232 connected Autoranging DMM | + | |
- | * Oscilloscope - For testing signals. Dual trace | + | |
- | * Power Supply - Regulated lab power supply | + | |
- | * Digital Camera - For taking snaps to share with other MIDIBoxers | + | |
- | * Mini Torch - Let there be light. A AA Cell MagLight in your mouth means you get perfect light | + | |
- | ==== Drilling ==== | + | |
- | * Rotary Tool | + | |
- | * Drill Press - For accurate drilling of PCB's and faceplates | + | |
- | * Drill bit set | + | |
- | * Router bit set | + | |
- | * Nibbling tool - for making odd shaped holes (Careful! These can be savage) | + | |
- | * Reamer - for making odd shaped holes | + | |
- | * Center punch - For marking the location of holes to be drilled and scribing lines on metal | + | |
- | ==== Abrasive/Cutting ==== | + | |
- | * File Set - Flat, round, half round, rasp and needle | + | |
- | * Hacksaw - For cutting solid objects | + | |
- | * Spare Hacksaw Blades - For use by hand | + | |
- | * Coping Saw - For cutting holes in cases | + | |
- | * Razor Knife - Stanley/X-Acto, etc. NOT for use on plastic cases unless you have a death wish | + | |
- | ==== Measurement ==== | + | |
- | * Flexible Steel Ruler with Cork backing - From Arts stores. An excellent idea that I stole ;) | + | |
- | * Calipers - For measuring drill bits, shaft diameters, and hole diameters | + | |
- | * Clamps/Vices - Various sizes and shapes, for holding things still while you drill/saw/bust them up | + | |
- | ==== Trimming and Fastening ==== | + | |
- | * Wire Strippers - For stripping insulation from cabling | + | |
- | * Pliers Set - Various Sizes and types | + | |
- | * Side Cutters - For trimming componenet leads | + | |
- | * Screwdriver Set - Various sizes | + | |
- | * Spanner Set - Various sizes, including shifter spanners | + | |
- | * Socket Set - Various sizes | + | |
- | * IC Puller - Little tool for pulling IC's from sockets | + | |
- | * IC Placer - Little tool for putting IC's in sockets, spreads even pressure over all the pins. | + | |
- | * Claw - One of those little pens with a three-fingered claw for grabbing loose bits from where fingers can't reach | + | |
- | ==== Accessories ==== | + | |
- | * Mirror - Little mirror on a telescopic shaft for peeking where your eyes can't reach | + | |
- | * Compressed Air Can - For cleaning stuff by blasting off dust | + | |
- | * PC/Mac - For surfing ucapps.de, the forum, this wiki, etc, for printing stuff, for talking to the DMM | + | |
- | * Internet Connection - You will need a fairly high-speed connection for downloading instructional images, PDFs, tools, etc. 56kbps will probably not be enough. I recommend 128kbps ADSL at the very minimum. I've got 12Mb ADSL2+ which is the fastest thing available, and recommend it highly. | + | |
- | * Printer - For everything from quick reference guides to datasheets to documentation to PCB screens to...... | + | |
+ | You don't absolutely //need// to have all of these things, but it sure helps! Using a tool for purposes other than those for which it was designed can be just a little more difficult, or downright dangerous. Please be safe :) | ||
- | Please note that I haven't mentioned any PCB creation tools... I don't make my own PCB's yet, so Internet Explorer (pointed at Smash's Shop) is the only tool I need for this. I don't think that will last due to some other projects I'm doing (I haven't given upon the SRAM yet!), so I will put PCB tools up here one day, but until then, please feel free to add them yourself! | ||
+ | ====== Lab Supplies ====== | ||
+ | A few handy things to have around the lab for experimenting.... | ||
+ | * a complete set of resistors, | ||
+ | * breadboard PCBs to mount hardware-parts | ||
+ | * sockets with screws (eg for DIN-buttons) | ||
+ | * set of capacitors (esp. those 104's) | ||
+ | * some additional switches (like power-switches) | ||
+ | * enough cables with connectors | ||
====== Thoughts ====== | ====== Thoughts ====== |
