syntax
Differences
syntax [2006/03/28 03:59] – smashtv | syntax [2006/03/28 04:06] – smashtv | ||
Line 51: | Line 51: | ||
are converted to lowercase automatically, | are converted to lowercase automatically, | ||
- | You can use [[wiki: | + | You can use [[http:// |
You can use [[wiki: | You can use [[wiki: | ||
Line 203: | Line 203: | ||
===== Typography ===== | ===== Typography ===== | ||
- | [[DokuWiki]] can convert simple text characters to their typographically correct entities. Here is an example of recognized characters. | + | [[wiki:DokuWiki]] can convert simple text characters to their typographically correct entities. Here is an example of recognized characters. |
-> <- <-> => <= <=> >> << -- --- 640x480 (c) (tm) (r) | -> <- <-> => <= <=> >> << -- --- 640x480 (c) (tm) (r) |
syntax.txt · Last modified: 2006/10/15 09:35 by 127.0.0.1
