syntax
Differences
Both sides previous revisionPrevious revision | Next revisionBoth sides next revision | ||
syntax [2006/03/28 04:06] – smashtv | syntax [2006/03/28 04:07] – smashtv | ||
Line 148: | Line 148: | ||
If you specify a filename (external or internal) that is not an image ('' | If you specify a filename (external or internal) that is not an image ('' | ||
- | For linking an image to another page see [[Image Links]] above. | + | For linking an image to another page see Image Links above. |
===== Lists ===== | ===== Lists ===== |
syntax.txt · Last modified: 2006/10/15 09:35 by 127.0.0.1
