syntax
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
syntax [2006/03/28 04:06] – smashtv | syntax [2006/03/28 04:09] – smashtv | ||
Line 1: | Line 1: | ||
- | ====== Formatting Syntax ====== | ||
- | [[wiki: | ||
- | ===== Basic text formatting ===== | ||
- | DokuWiki supports **bold**, //italic//, __underlined__ and '' | ||
- | Of course you can **__//'' | ||
- | You can use < | ||
- | You can mark something as < | ||
- | **Paragraphs** are created from blank lines. If you want to **force a newline** without a paragraph, you can use two backslashes followed by a whitespace or the end of line. | ||
- | This is some text with some linebreaks\\ Note that the | ||
- | two backslashes are only recognized at the end of a line\\ | ||
- | or followed by\\ a whitespace \\this happens without it. | ||
- | You should use forced newlines only if really needed. | ||
- | ===== Links ===== | ||
- | DokuWiki supports multiple ways of creating links. | ||
- | ==== External ==== | ||
- | External links are recognized automagically: | ||
- | DokuWiki supports multiple ways of creating links. External links are recognized | ||
- | automagically: | ||
- | Linknames, too: [[http:// | ||
- | addresses like this one: < | ||
- | ==== Internal ==== | ||
- | Internal links are created by using square brackets. You can either just give a [[doku> | ||
- | Internal links are created by using square brackets. You can either just give | ||
- | a [[pagename]] or use an additional [[pagename|Title Text]]. Wiki pagenames | ||
- | are converted to lowercase automatically, | ||
- | You can use [[http:// | ||
- | You can use [[wiki: | ||
- | For details about namespaces see [[doku> | ||
- | Linking to a specific section is possible, too. Just add the sectionname behind a hash character as known from HTML. This links to [[syntax# | ||
- | This links to [[syntax# | ||
- | Notes: | ||
- | * Links to [[wiki: | ||
- | * DokuWiki does not use [[wp> | ||
- | * When a section' | ||
- | ==== Interwiki ==== | ||
- | DokuWiki supports [[doku> | ||
- | For example this is a link to Wikipedia' | ||
- | ==== Image Links ==== | ||
- | You can also use an image to link to another internal or external page by combining the syntax for links and [[# | ||
- | [[http:// | ||
- | [[http:// | ||
- | Please note: The image formatting is the only formatting syntax accepted in link names. | ||
- | The whole [[# | ||
- | ===== Footnotes ===== | ||
- | You can add footnotes ((This is a footnote)) by using double parenthesises. | ||
- | ===== Sectioning ===== | ||
- | You can use up to five different levels of headlines to structure your content. If you have more than three headlines, a table of contents is generated automatically -- this can be disabled by including the string ''< | ||
- | ==== Headline Level 3 ==== | ||
- | === Headline Level 4 === | ||
- | == Headline Level 5 == | ||
- | By using four or more dashes, you can make a horizontal line: | ||
- | ===== Images and other files ===== | ||
- | You can include external and internal [[doku> | ||
- | Real size: {{wiki: | ||
- | Resize to given width: | ||
- | Resize to given width and height: {{wiki: | ||
- | Resized external image: | ||
- | By using left or right whitespaces you can choose the alignment | ||
- | {{ wiki: | ||
- | {{wiki: | ||
- | {{ wiki: | ||
- | {{ wiki: | ||
- | {{wiki: | ||
- | {{ wiki: | ||
- | Of course, you can add a title (displayed as a tooltip by most browsers), too. | ||
- | {{ wiki: | ||
- | {{ wiki: | ||
- | If you specify a filename (external or internal) that is not an image ('' | ||
- | For linking an image to another page see [[Image Links]] above. | ||
- | ===== Lists ===== | ||
- | Dokuwiki supports ordered and unordered lists. To create a list item, indent your text by two spaces and use a '' | ||
- | * This is a list | ||
- | * The second item | ||
- | * You may have different levels | ||
- | * Another item | ||
- | - The same list but ordered | ||
- | - Another item | ||
- | - Just use indention for deeper levels | ||
- | - That's it | ||
- | ===== Smileys ===== | ||
- | DokuWiki converts commonly used [[wp> | ||
- | * 8-) %% 8-) %% | ||
- | * 8-O %% 8-O %% | ||
- | * :-D %% :-D %% | ||
- | * :-P %% :-P %% | ||
- | * :-O %% :-O %% | ||
- | * :-X %% :-X %% | ||
- | * ^_^ %% ^_^ %% | ||
- | * LOL %% LOL %% | ||
- | * FIXME %% FIXME %% | ||
- | * DELETEME %% DELETEME %% | ||
- | ===== Typography ===== | ||
- | [[wiki: | ||
- | -> <- <-> => <= <=> >> << -- --- 640x480 (c) (tm) (r) | ||
- | "He thought ' | ||
- | Please note: These conversions can be turned off in the config file. | ||
- | ===== Quoting ===== | ||
- | Some times you want to mark some text to show it's a reply or comment. You can use the following syntax: | ||
- | I think we should do it | ||
- | > No we shouldn' | ||
- | >> Well, I say we should | ||
- | > Really? | ||
- | >> Yes! | ||
- | > Really? | ||
- | >> Yes! | ||
- | ===== Tables ===== | ||
- | DokuWiki supports a simple syntax to create tables. | ||
- | ^ Heading 1 ^ Heading 2 ^ Heading 3 ^ | ||
- | | Row 1 Col 1 | Row 1 Col 2 | Row 1 Col 3 | | ||
- | | Row 2 Col 1 | some colspan (note the double pipe) || | ||
- | | Row 3 Col 1 | Row 2 Col 2 | Row 2 Col 3 | | ||
- | Table rows have to start and end with a '' | ||
- | To connect cells horizontally, | ||
- | Vertical tableheaders are possible, too. | ||
- | | ^ Heading 1 ^ Heading 2 ^ | ||
- | ^ Heading 3 | Row 1 Col 2 | Row 1 Col 3 | | ||
- | ^ Heading 4 | no colspan this time | | | ||
- | ^ Heading 5 | Row 2 Col 2 | Row 2 Col 3 | | ||
- | As you can see, it's the cell separator before a cell which decides about the formatting: | ||
- | Note: Vertical spans (rowspan) are not possible. | ||
- | You can align the table contents, too. Just add at least two whitespaces at the opposite end of your text: Add two spaces on the left to align right, two spaces on the right to align left and two spaces at least at both ends for centered text. | ||
- | ^ Table with alignment | ||
- | |left | | ||
- | | xxxxxxxxxxxx | xxxxxxxxxxxx | xxxxxxxxxxxx | | ||
- | This is how it looks in the source: | ||
- | |left | | ||
- | ===== Nonparsed Blocks ===== | ||
- | You can include non parsed blocks into your documents by either indenting them by at least two spaces (like used for the previous examples) or by using the tags '' | ||
- | This is preformatted code all spaces are preserved: like <-this | ||
- | This is pretty much the same, but you could use it to show that you quoted a file. | ||
- | To let the parser ignore an area completely (ie. do no formatting on it), enclose the area either with '' | ||
- | This is some text which contains addresses like this: http:// | ||
- | See the source of this page to see how to use these blocks. | ||
- | ===== Syntax Highlighting ===== | ||
- | [[DokuWiki]] can highlight sourcecode, which makes it easier to read. It uses the [[http:// | ||
- | <code java> | ||
- | * The HelloWorldApp class implements an application that | ||
- | * simply displays "Hello World!" | ||
- | class HelloWorldApp { | ||
- | public static void main(String[] args) { | ||
- | System.out.println(" | ||
- | The following language strings are currently recognized: // | ||
- | ===== Embedding HTML and PHP ===== | ||
- | You can embed raw HTML or PHP code into your documents by using the '' | ||
- | This is some <font color=" | ||
- | <php> | ||
- | echo 'A logo generated by PHP:'; | ||
- | echo '< | ||
- | <php> | ||
- | echo '< | ||
- | **Please Note**: HTML and PHP embedding is disabled by default in the configuration. If disabled, the code is displayed instead of executed. | ||
- | ===== Syntax Plugins ===== | ||
- | DokuWiki' | ||
- | ~~INFO: |
syntax.txt · Last modified: 2006/10/15 09:35 by 127.0.0.1
