tpd_pcb
Differences
tpd_pcb [2015/10/28 20:53] – [Frontpanel] arnonym | tpd_pcb [2018/03/22 22:48] – [Where to buy?] ilmenator | ||
Line 1: | Line 1: | ||
====== MIDIbox SEQ Track Position Display module ====== | ====== MIDIbox SEQ Track Position Display module ====== | ||
- | Based on an original idea by Hawkeye who implemented an 8x8 LED matrix display to show the current track position in his MB SEQ, I designed the TPD module. It does not only provide an enlarged (and duo-color) LED matrix, but also a BPM display and dedicated tempo/BPM encoder, a step display, and four freely assignable buttons with adjacent duo-LEDs for status feedback. | + | {{youtube> |
- | {{http:// | + | ===== Introduction ===== |
+ | Based on an original idea by Hawkeye who implemented an 8x8 LED matrix display to show the current track position in his MB SEQ, I designed the TPD module. It does not only provide an enlarged (and duo-color) LED matrix, but also a BPM display and dedicated tempo/BPM encoder, a step display, and four freely assignable buttons with adjacent duo-LEDs for status feedback. | ||
In my MIDIbox SEQv4, the TPD is sitting below Wilba' | In my MIDIbox SEQv4, the TPD is sitting below Wilba' | ||
Line 24: | Line 25: | ||
==== Where to buy? ==== | ==== Where to buy? ==== | ||
- | If you are interested in building this, send a personal message (PM) to user // | + | If you are interested in building this, send a personal message (PM) to user // |
+ | ===== Euro TPD format ===== | ||
+ | Since November 2016, there is also a Euro Rack compatible PCB available that has slightly modified dimensions and component placement. Alas, the mounting holes have also been moved around a bit. This was necessary to make the TPD compatible with the Doepfer Euro Rack series - a little taller and a little less wide. | ||
+ | The Euro TPD uses the same components and footprints as the " | ||
===== BOM ===== | ===== BOM ===== | ||
Line 105: | Line 112: | ||
A config file suitable for use with the TPD module chained after my [[http:// | A config file suitable for use with the TPD module chained after my [[http:// | ||
+ | Some users have reported problems when the TPD is not the last module in the DIN/DOUT chain, presumably because the are 9 DOUTs on this module, but just one DIN, which in turn leads to an unbalanced serial output, see [[http:// |
tpd_pcb.txt · Last modified: 2022/05/11 06:56 by ilmenator
