troubleshooting
Differences
troubleshooting [2016/06/10 15:00] – ↷ Links adapted because of a move operation 192.243.55.131 | troubleshooting [2016/06/14 02:53] – psykhaze | ||
Line 1: | Line 1: | ||
- | \\ | + | ====== Troubleshooting ====== |
+ | :!: **[[frequently_asked_questions_faq|Have you read the General FAQ]]?** :!: | ||
FIXME \\ | FIXME \\ | ||
-> Please add to this page any fixes to problems you have had.\\ | -> Please add to this page any fixes to problems you have had.\\ | ||
-> Add links to all the troubleshooting procedures on ucapps.de and eventuaqlly convert them all to wiki format | -> Add links to all the troubleshooting procedures on ucapps.de and eventuaqlly convert them all to wiki format | ||
- | \\ | + | ===== Golden Rules of Troubleshooting ===== |
- | :!: **Reminder: | + | |
- | -> **[[frequently_asked_questions_faq|Have you read the FAQ]]?** | + | |
- | ====== Golden Rules of Troubleshooting | + | |
Hi, I'm stryd_one. I'm a professional IT engineer who fixes bugs for a living, and I've been hanging around here long time, and seen a lot of bugs come and go.... Here are some tips which would solve 99% of the problems I've seen. I hope that you'll pay attention to these rules, and that they' | Hi, I'm stryd_one. I'm a professional IT engineer who fixes bugs for a living, and I've been hanging around here long time, and seen a lot of bugs come and go.... Here are some tips which would solve 99% of the problems I've seen. I hope that you'll pay attention to these rules, and that they' | ||
Line 55: | Line 52: | ||
stryd_one | stryd_one | ||
- | \\ | + | ===== Control Surface Troubleshooting ===== |
- | ====== Control Surface Troubleshooting | + | |
Please see the page [[control_surface_troubleshooting]] | Please see the page [[control_surface_troubleshooting]] | ||
- | ====== LCD Troubleshooting | + | ===== LCD Troubleshooting ===== |
Please see the page [[Troubleshooting LCD Displays]] | Please see the page [[Troubleshooting LCD Displays]] | ||
- | ====== MIDI Troubleshooting | + | ===== MIDI Troubleshooting ===== |
Please see the page [[midi_troubleshooting]] | Please see the page [[midi_troubleshooting]] | ||
Line 81: | Line 76: | ||
Solution: connect all open analog pins to ground. Not only the unused pins at J5 of the core module, but also all unused analog inputs of the AINX4 module! If this still doesn' | Solution: connect all open analog pins to ground. Not only the unused pins at J5 of the core module, but also all unused analog inputs of the AINX4 module! If this still doesn' | ||
- | \\ | + | ===== AIN/Pots Troubleshooting ===== |
- | ====== AIN/Pots Troubleshooting ====== | ||
- | \\ | + | ==== How can I avoid pot flickering/ |
- | ===== How can I avoid pot flickering/ | + | |
Most of the MIDIbox users don't experience pot flickering, whatever type of board they have created (PCB or prototyping boards) - following hints are intended for people who notice an continuous MIDI stream or sporadic, unwanted MIDI events coming out of their box. | Most of the MIDIbox users don't experience pot flickering, whatever type of board they have created (PCB or prototyping boards) - following hints are intended for people who notice an continuous MIDI stream or sporadic, unwanted MIDI events coming out of their box. | ||
Line 108: | Line 102: | ||
===== Starlike-Wiring ===== | ===== Starlike-Wiring ===== | ||
- | Starlike Wiring helps to reduce jitter! | + | Starlike Wiring helps to reduce jitter!Read the [[http:// |
- | Read the description here: http:// | + | |
- | **-- Click to Enlarge --** | + | |
{{http:// | {{http:// | ||
===== Current Drain ===== | ===== Current Drain ===== |
troubleshooting.txt · Last modified: 2016/06/15 13:01 by psykhaze
