user_projects
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
user_projects [2016/09/11 10:56] – antichambre | user_projects [2020/05/23 16:28] (current) – antichambre | ||
Line 31: | Line 31: | ||
* **[[MIDIbox UC]]** - Universal Control: Extended SysEx Handler | * **[[MIDIbox UC]]** - Universal Control: Extended SysEx Handler | ||
* **[[mb-lre8x2cs_pcb|MB-LRE8x2]]**- 16 Led rings encoders | * **[[mb-lre8x2cs_pcb|MB-LRE8x2]]**- 16 Led rings encoders | ||
+ | * **[[msq-cc-lre|msq-cc-lre]]**- 8Ch x 32CC Bank-Syntheditor with Motion Automatition and Velocity Offset from Triggers - based on 2x LRE8x2 | ||
+ | * **[[msq-cc-bcr|msq-cc-bcr]]**- 8Ch x 32CC Bank-Syntheditor with Motion Automatition and Velocity Offset from Triggers - with BCR2000 instead of LRE - Nord Drum Edition\\ | ||
//In Progress // | //In Progress // | ||
- | * [[MB-Modulbox-NG]] | + | * [[MB-Modulbox-NG]] Modular |
+ | * [[mb_olre16|MB_OLRE16]]- 1 row of 16 encoders with oleds and 32 segments RGB led rings. | ||
* [[The Thing by Mpro-ject|The Thing DJ-Mixer]] | * [[The Thing by Mpro-ject|The Thing DJ-Mixer]] | ||
Line 42: | Line 45: | ||
* [[Korg Wavedrum MIDIfication]] | * [[Korg Wavedrum MIDIfication]] | ||
* [[Velocity converter]] | * [[Velocity converter]] | ||
- | * [[mb_olre16|MB_OLRE16]]- 1 row of 16 encoders with oleds and 32 segments RGB led rings. | + | |
Line 69: | Line 72: | ||
- | * [[MB-EuroSynth]] - Eurorack | + | * [[MB-ReSynth]] - 4U FM/TIA/SID Synths |
- | * [[MB-EuRoland]] - Eurorack | + | * [[MB-DigiRoland]] - Roland Analog Drums driven by digital Pots |
* [[MIDIbox Quad Genesis]] - Up to four Sega Genesises' | * [[MIDIbox Quad Genesis]] - Up to four Sega Genesises' | ||
Line 96: | Line 99: | ||
* **[[ssm2044_pcb|SSM2044 VCF]]** - Low pass filter board | * **[[ssm2044_pcb|SSM2044 VCF]]** - Low pass filter board | ||
+ | * **[[clock2audio2clock]]** - Record/ | ||
+ | * **[[dipCoreF4]]** - An STM32F4 Compact Core. | ||
//In Progress// | //In Progress// | ||
Line 104: | Line 109: | ||
* [[MBlight Mind-Machine]] - an audio/ | * [[MBlight Mind-Machine]] - an audio/ | ||
- | * [[MB-Euroscope]] - Eurorack | + | * [[mb-scope]] - 6ins+2sync Dual TFT Scope |
* [[midibox_audiomatrix|MIDIbox Audio Matrix]] - digitally controlled analogue audio/CV patch router | * [[midibox_audiomatrix|MIDIbox Audio Matrix]] - digitally controlled analogue audio/CV patch router | ||
Line 111: | Line 116: | ||
* [[ssm2164_pcb|SSM2164 VCA]] - Quad channel VCA board | * [[ssm2164_pcb|SSM2164 VCA]] - Quad channel VCA board | ||
* [[EASY CV]] - EuroRack-sized - 8x LFO+ENV-combi with 8AOUTChannels for VCA-VCF based Setups | * [[EASY CV]] - EuroRack-sized - 8x LFO+ENV-combi with 8AOUTChannels for VCA-VCF based Setups | ||
+ | * [[mb_2069|MIDIbox 2069]] - Based on the KORG NJM2069 Music Voicing System | ||
Line 124: | Line 130: | ||
* **[[DSEQ32]]** - 32 step drumseq | * **[[DSEQ32]]** - 32 step drumseq | ||
* **[[chaos_matrix|Chaos Matrix]]** Oberheim Matrix 1000 Programmer | * **[[chaos_matrix|Chaos Matrix]]** Oberheim Matrix 1000 Programmer | ||
+ | * **[[haarp|The HAARP]]** - Hardware Advanced Arpeggiator. | ||
* [[Triggermatrix]] - 16track Trigger-Sequencer & Trigger-router - a liveact based center of a midisetup | * [[Triggermatrix]] - 16track Trigger-Sequencer & Trigger-router - a liveact based center of a midisetup | ||
+ | * [[16th fixed PolySequencer]] - 16th fixed 2x4track-poly-Sequencer - the poly note/ | ||
* [[AlternativeSequencer]] - Alternative ideas for sequencers | * [[AlternativeSequencer]] - Alternative ideas for sequencers | ||
* [[MB808]] - 808 Clone Sequencer | * [[MB808]] - 808 Clone Sequencer | ||
+ | * [[MB909]] - 909 Full Clone | ||
user_projects.txt · Last modified: 2020/05/23 16:28 by antichambre
