user_projects
Differences
user_projects [2017/08/21 09:44] – antichambre | user_projects [2018/05/12 10:40] – phatline | ||
Line 31: | Line 31: | ||
* **[[MIDIbox UC]]** - Universal Control: Extended SysEx Handler | * **[[MIDIbox UC]]** - Universal Control: Extended SysEx Handler | ||
* **[[mb-lre8x2cs_pcb|MB-LRE8x2]]**- 16 Led rings encoders | * **[[mb-lre8x2cs_pcb|MB-LRE8x2]]**- 16 Led rings encoders | ||
+ | * **[[msq-cc-lre|msq-cc-lre]]**- 8Ch x 32CC Bank-Syntheditor with Motion Automatition and Velocity Offset from Triggers - based on 2x LRE8x2 | ||
+ | * **[[msq-cc-lre|msq-cc-lre]]**- 8Ch x 32CC Bank-Syntheditor with Motion Automatition and Velocity Offset from Triggers - with BCR2000 instead of LRE - Nord Drum Edition\\ | ||
//In Progress // | //In Progress // | ||
Line 97: | Line 100: | ||
* **[[ssm2044_pcb|SSM2044 VCF]]** - Low pass filter board | * **[[ssm2044_pcb|SSM2044 VCF]]** - Low pass filter board | ||
+ | * **[[clock2audio2clock]]** - Record/ | ||
//In Progress// | //In Progress// | ||
Line 129: | Line 133: | ||
* [[Triggermatrix]] - 16track Trigger-Sequencer & Trigger-router - a liveact based center of a midisetup | * [[Triggermatrix]] - 16track Trigger-Sequencer & Trigger-router - a liveact based center of a midisetup | ||
+ | * [[16th fixed PolySequencer]] - 16th fixed 2x4track-poly-Sequencer - the poly note/ | ||
* [[AlternativeSequencer]] - Alternative ideas for sequencers | * [[AlternativeSequencer]] - Alternative ideas for sequencers | ||
* [[MB808]] - 808 Clone Sequencer | * [[MB808]] - 808 Clone Sequencer |
user_projects.txt · Last modified: 2020/05/23 16:28 by antichambre
