wikify [2008/12/01 07:24] this |
wikify [2008/12/19 15:42] stryd_one This namespace is tricky but I think I got it |
Line 1: | Line 1: | ||
====== MIDIbox Wiki Instructions ====== | ====== MIDIbox Wiki Instructions ====== | ||
- | =====Wiki Syntax==== | + | ====== Wiki Syntax ====== |
The best way to learn the syntax and how it is used in the midibox-wiki is just to study existing pages. The syntax is easy to read and learn.\\ | The best way to learn the syntax and how it is used in the midibox-wiki is just to study existing pages. The syntax is easy to read and learn.\\ | ||
Follow [[http://www.dokuwiki.org/syntax|this]] link to learn more about the syntax. | Follow [[http://www.dokuwiki.org/syntax|this]] link to learn more about the syntax. | ||
- | =====About Namespaces===== | + | ====== Namespaces ====== |
- | All wiki-pages are organized in namespaces. A namespace works excatly like a folder, ':' is used as a separator, links can be absolute or relative to the current namespace: | + | All wiki-pages are organized in namespaces. A namespace works exactly like a folder on your PC, but instead of a slash '/', a colon ':' is used as a separator. Links can be absolute or relative to the current namespace: |
- | '[[:home | Home]]' links to the page 'home' in the root namespace | + | '[[:home]]' links to the page 'home' in the root namespace |
- | '[[.:mbhp:module:din | DIN digital inputs]]' links to the page 'mbhp:module:din' in the current namespace | + | '[[:mbhp:module:din]]' links to the page 'mbhp:module:din' in the root namespace |
- | '[[din_dout_pin_list | DIN & DOUT pin table]]' links to the page 'din_dout_pin_list' in the current namespace | + | '[[mbhp:module:din]]' links to the page 'mbhp:module:din' in the root namespace |
- | | + | '[[.:mbhp:module:din]]' links to the page 'mbhp:module:din' in the current namespace |
- | The text before the '|' is the page to link to, the one after it is the linked text. | + | '[[din_dout_pin_list]]' links to the page 'din_dout_pin_list' in the current namespace |
- | note that 'mbhp:module:din' would **not** be relative to the current namespace. It would be equivalent to ':mbhp:module:din' | + | |
Line 23: | Line 21: | ||
However, in most cases it will be easier and safer to just use absolute links. | However, in most cases it will be easier and safer to just use absolute links. | ||
- | =====Namespace Map===== | + | ===== Namespace Map ===== |
This is the namespace-structure of the midibox-wiki. All information concerning the midibox-project has to be somwhere in the 'home' namespace, the 'wikify' namespace is the place for information about how to edit/update the midibox-wiki. | This is the namespace-structure of the midibox-wiki. All information concerning the midibox-project has to be somwhere in the 'home' namespace, the 'wikify' namespace is the place for information about how to edit/update the midibox-wiki. | ||
* home | * home | ||
+ | * about | ||
+ | * faq | ||
* project | * project | ||
* controller | * controller | ||
Line 40: | Line 40: | ||
* pic | * pic | ||
* stm32 | * stm32 | ||
- | * mios | + | * software |
- | * mios32 | + | * pc |
+ | * osx | ||
+ | * linux | ||
+ | * windows | ||
+ | * xplatform | ||
+ | * mbhp | ||
+ | * mios | ||
+ | * mios32 | ||
+ | * code | ||
+ | * picasm | ||
+ | * c | ||
+ | * c++ | ||
* skills | * skills | ||
- | * troubleshooting | + | * troubleshooting |
- | * svn | + | |
* community | * community | ||
- | * bulk_order | + | * bulk_order |
* wikify | * wikify | ||
* template | * template | ||
+ | ====== Global Documentation ====== | ||
+ | [[:wikify:home | Homepage template]], with templates for child pages, as per the above namespace map. | ||
- | =====Documenting Projects===== | + | ===== Documenting Projects ===== |
[[:wikify:documenting_your_project | Documenting your project]] | [[:wikify:documenting_your_project | Documenting your project]] | ||
[[:wikify:template:project | Project Template]] | [[:wikify:template:project | Project Template]] | ||
- | =====Documenting Modules===== | + | ===== Documenting Modules ===== |
[[:wikify:docmenting_your_module | Documenting your module]] | [[:wikify:docmenting_your_module | Documenting your module]] | ||
[[:wikify:template:module | Module Template]] | [[:wikify:template:module | Module Template]] |
