windows_toolchain_core [2009/11/12 20:34] admin msys installation not required anymore |
windows_toolchain_core [2010/11/30 20:44] baeaeaeaeaer |
Line 5: | Line 5: | ||
** Don't forget [[http://www.midibox.org/dokuwiki/windows_toolchain_quickstart|The QuickStart Guide!]]** | ** Don't forget [[http://www.midibox.org/dokuwiki/windows_toolchain_quickstart|The QuickStart Guide!]]** | ||
It's the quick and easy setup. It will work for nearly everyone.\\ | It's the quick and easy setup. It will work for nearly everyone.\\ | ||
+ | ** Please note that this page is only for MIOS8.** | ||
+ | For the more powerful STM32 based MIOS32, please visit [[http://www.midibox.org/dokuwiki/doku.php?id=windows_mios32_toolchain_core&s|The MIOS32 Setup Guide!]]\\ | ||
Line 31: | Line 34: | ||
====== Preparation ====== | ====== Preparation ====== | ||
Line 64: | Line 68: | ||
====== Required Tools ====== | ====== Required Tools ====== | ||
===== MSYS ===== | ===== MSYS ===== | ||
MSYS provides us with a POSIX (UNIX style) environment for our Windows PC. This packages includes tools such as make and sed and sh, which are required to correctly run gputils later on. I recommend the latest version, but v1.0.10 has tested OK. | MSYS provides us with a POSIX (UNIX style) environment for our Windows PC. This packages includes tools such as make and sed and sh, which are required to correctly run gputils later on. I recommend the latest version, but v1.0.10 has tested OK. | ||
If you are going to use MinGW for AC-Sim, ensure that you have installed that completely before performing the MSYS install. See the above step in this document. | If you are going to use MinGW for AC-Sim, ensure that you have installed that completely before performing the MSYS install. See the above step in this document. | ||
- | * [[http://sourceforge.net/projects/mingw/files/MSYS%20Base%20System/msys-1.0.11/MSYS-1.0.11.exe/download|Download MSYS]] | + | * [[http://downloads.sourceforge.net/mingw/MSYS-1.0.11.exe|Download MSYS]] (more info [[http://www.mingw.org/wiki/MSYS|here]]) |
* Install using the defaults. | * Install using the defaults. | ||
* When the install is almost complete, you will see a DOS console window open, and you will be prompted: "Do you wish to continue with the post install? [yn ]". Type 'y' (without the quotes) and hit Enter. | * When the install is almost complete, you will see a DOS console window open, and you will be prompted: "Do you wish to continue with the post install? [yn ]". Type 'y' (without the quotes) and hit Enter. |
