how_to_use_aout_seq_v2
Differences
Link to this comparison view
Both sides previous revisionPrevious revision
Next revision
Previous revision
how_to_use_aout_seq_v2 [2006/03/16 16:31] smashtvhow_to_use_aout_seq_v2 [2006/10/15 09:35] (current) – external edit 127.0.0.1
Line 4: Line 4:
 If you want to route a sequencer track to the AOUT module: If you want to route a sequencer track to the AOUT module:
- +  - go to the "EVENT" page of the menu.
-   - go to the "EVENT" page of the menu. +  - select "AOUT"
-   - select "AOUT" +  - select the desired "Channel" (1-16)
-   - select the desired "Channel" (1-16)+
 The 16 "Channels" represent different modes of the AOUT: The 16 "Channels" represent different modes of the AOUT:
-   Channel 1-4 are used for notes. +  * Channel 1-4 are used for notes.
-     - Channel 1: Gate 1, Note Value -> CV 1, VEL Value -> CV 2 +  - Channel 1: Gate 1, Note Value -> CV 1, VEL Value -> CV 2
-     - Channel 2: Gate 2, Note Value -> CV 3, VEL Value -> CV 4 +  - Channel 2: Gate 2, Note Value -> CV 3, VEL Value -> CV 4
-     - Channel 3: Gate 3, Note Value -> CV 5, VEL Value -> CV 6 +  - Channel 3: Gate 3, Note Value -> CV 5, VEL Value -> CV 6
-     - Channel 4: Gate 4, Note Value -> CV 7, VEL Value -> CV 8+  - Channel 4: Gate 4, Note Value -> CV 7, VEL Value -> CV 8
-   - Chanel 5-8 are used for controller data. +  * Channel 5-8 are used for controller data.
-     - Channel 5: Gate 1, CC -> CV 1, VEL Value -> CV 2 +  - Channel 5: Gate 1, CC -> CV 1, VEL Value -> CV 2
-     - Channel 6: Gate 2, CC -> CV 3, VEL Value -> CV 4 +  - Channel 6: Gate 2, CC -> CV 3, VEL Value -> CV 4
-     - Channel 7: Gate 3, CC -> CV 5, VEL Value -> CV 6 +  - Channel 7: Gate 3, CC -> CV 5, VEL Value -> CV 6
-     - Channel 8: Gate 4, CC -> CV 7, VEL Value -> CV 8+  - Channel 8: Gate 4, CC -> CV 7, VEL Value -> CV 8
-   Channel 9-16 are used for direct acces to the CV's 1-8 via LAYER B/Velocity!!! +  * Channel 9-16 are used for direct acces to the CV's 1-8 via LAYER B/Velocity!!!
-     - Channel  9: VEL Value - > CV 1 +  - Channel  9: VEL Value - > CV 1
-     - Channel 10: VEL Value - > CV 2 +  - Channel 10: VEL Value - > CV 2
-     - Channel 11: VEL Value - > CV 3 +  - Channel 11: VEL Value - > CV 3
-     - Channel 12: VEL Value - > CV 4 +  - Channel 12: VEL Value - > CV 4
-     - Channel 13: VEL Value - > CV 5 +  - Channel 13: VEL Value - > CV 5
-     - Channel 14: VEL Value - > CV 6 +  - Channel 14: VEL Value - > CV 6
-     - Channel 15: VEL Value - > CV 7 +  - Channel 15: VEL Value - > CV 7
-     - Channel 16: VEL Value - > CV 8+  - Channel 16: VEL Value - > CV 8
 Gate 3/4 are a planned feature and not implemented in the hardware yet. Gate 3/4 are a planned feature and not implemented in the hardware yet.
how_to_use_aout_seq_v2.1142526679.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
