how_to_use_midibox_cv_with_a_dout
Differences
| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| how_to_use_midibox_cv_with_a_dout [2006/06/15 16:43] – clean up english version grammar DrBunsen | how_to_use_midibox_cv_with_a_dout [2009/05/06 14:23] (current) – 129.120.95.63 | ||
| Line 13: | Line 13: | ||
| independent of the Note duration. | independent of the Note duration. | ||
| - | Here as background is the trigger characteristic of some drum machines. The x0x-boxes (606, | + | Here as background is the trigger characteristic of some drum machines. The x0x-boxes (606, |
| - | Activate | + | __Activate |
| Download the source of Midibox CV at http:// | Download the source of Midibox CV at http:// | ||
| Line 44: | Line 44: | ||
| movlw 0x90 ; | movlw 0x90 ; | ||
| - | IFNEQ MIOS_PARAMETER1, | + | cpfseq |
| + | rgoto USER_MPROC_NRE_NoNoteChn1 | ||
| USER_MPROC_NRE_NoteChn1 | USER_MPROC_NRE_NoteChn1 | ||
| ;; MIOS_DOUT_PinSet expects pin number in WREG, value in MIOS_PARAMETER1 | ;; MIOS_DOUT_PinSet expects pin number in WREG, value in MIOS_PARAMETER1 | ||
| Line 70: | Line 71: | ||
| activates the corresponding dout. A NoteOff deactivates the dout. | activates the corresponding dout. A NoteOff deactivates the dout. | ||
| + | __Define the number of connected DOUT shift registers: | ||
| - | 1ms extension for Vintage | + | If you're using more than one DOUT shift register, you must also change this code in " |
| + | ;; initialize the SRIO driver | ||
| + | movlw 0x01 | ||
| + | call MIOS_SRIO_NumberSet | ||
| + | To set it to the maximum (16), just replace the code with this: | ||
| + | movlw 0x0F | ||
| + | __1ms Extension For Vintage | ||
| - | Those who want to trigger | + | Those who want to trigger |
| Search for the following: | Search for the following: | ||
| Line 101: | Line 118: | ||
| with a 1ms latency. | with a 1ms latency. | ||
| - | (Would it be possible | + | MIDIbox SEQ allows up to 48 digital outputs as this type of trigger. [[http:// |
| + | __Changing the midi channel: | ||
| + | If you want the DOUT triggers | ||
| + | * Channel 1: 0x80, 0x90 | ||
| + | * Channel 2: 0x81, 0x91 | ||
| + | * Channel 3: 0x82, 0x92 | ||
| + | * Channel 4: 0x83, 0x93 | ||
| + | * Channel 5: 0x84, 0x94 | ||
| + | * Channel 6: 0x85, 0x95 | ||
| + | * Channel 7: 0x86, 0x96 | ||
| + | * Channel 8: 0x87, 0x97 | ||
| + | * Channel 9: 0x88, 0x98 | ||
| + | * Channel 10: 0x89, 0x99 | ||
| + | * Channel 11: 0x8A, 0x9A | ||
| + | * Channel 12: 0x8B, 0x9B | ||
| + | * Channel 13: 0x8C, 0x9C | ||
| + | * Channel 14: 0x8D, 0x9D | ||
| + | * Channel 15: 0x8E, 0x9E | ||
| + | * Channel 16: 0x8F, 0x9F | ||
| + | __Forum articles:__ | ||
| - | Forum articles: | + | [[http:// |
| - | http:// | + | [[http:// |
how_to_use_midibox_cv_with_a_dout.1150389816.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
