ju_control_roland_alpha_juno_control_panel_cs
Differences
| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| ju_control_roland_alpha_juno_control_panel_cs [2012/12/09 19:36] – lemonhorse | ju_control_roland_alpha_juno_control_panel_cs [2017/09/19 12:14] (current) – [MIDIBox Juno Control (JuCtrl)] lemonhorse | ||
| Line 1: | Line 1: | ||
| ====== MIDIBox Juno Control (JuCtrl) ====== | ====== MIDIBox Juno Control (JuCtrl) ====== | ||
| - | {{http://www.subfrequenz.net/ | + | {{https://www.subf.net/ |
| ====== Project Description ====== | ====== Project Description ====== | ||
| Line 357: | Line 357: | ||
| || --- V1.001 (12/ | || --- V1.001 (12/ | ||
| || --- JuCtrl MIDI IN: Channel Pressure (MIDI Aftertouch) enabled. | || --- JuCtrl MIDI IN: Channel Pressure (MIDI Aftertouch) enabled. | ||
| - | || Note: Juno Keyboard | + | |
| - | || You can use all the nice Aftertouch Effects of the Alpha Juno. | + | |
ju_control_roland_alpha_juno_control_panel_cs.1355081773.txt.gz · Last modified: 2012/12/09 19:36 by lemonhorse
