wikify:template:project
Differences
| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| wikify:template:project [2008/12/01 10:28] – Durisian | wikify:template:project [2008/12/20 03:53] (current) – stryd_one | ||
| Line 1: | Line 1: | ||
| - | ** STILL INCOMPLETE ** | + | ====== <Project Name> ====== |
| - | =====Intro===== | ||
| - | All about it, what it does and blah | + | ====== Intro ====== |
| - | =====Features===== | + | All about it, what it does and blah |
| - | List 'em | + | ====== Features ====== |
| - | =====Skills / Equipment Required===== | + | List 'em |
| - | * [[: | + | ====== Skills / Equipment Required ====== |
| - | =====Harware===== | ||
| - | ====What modules do I need?==== | ||
| - | Adjust List as required: | + | ====== Hardware ====== |
| - | * [[: | + | ===== What modules |
| - | * + Any custom | + | |
| + | Adjust List as required: | ||
| - | ====List of parts==== | + | [[: |
| - | list of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hool them up - links | + | [[: |
| + | Any custom modules (create link in ': | ||
| + | ===== Parts List ===== | ||
| + | List of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hook them up - links | ||
| - | ====Connections==== | + | ===== Connections |
| - | | + | Connection diagrams - links if needed (create in you projects namespace |
| - | ==== Enclosure / Case ==== | + | ===== Enclosure / Case ===== |
| Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs | Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs | ||
| - | === Enclosure References === | + | ==== Enclosure References |
| Line 62: | Line 80: | ||
| - | =====Software===== | + | ====== Software |
| - | ==== Setting Up ==== | + | ===== Setting Up ===== |
| - | PIC's must be setup with MIOS bootstrap Loader and MIOS before an application can be uploaded. \\ | + | |
| - | If you purchased you PIC from SmashTV or Mike's PCB Shop these will already installed. | + | |
| - | We recommend you read the following before you continue: | + | We recommend you read [[:home:software]] before you continue. |
| - | * [[:home:mios: | + | |
| - | * [[http:// | + | |
| - | ==== Download ==== | + | ===== Download |
| - | links | + | Links |
| - | ==== Setup Instructions ==== | + | ===== Setup Instructions |
| - | | + | Up to you |
| - | =====Extra===== | + | ====== Extra ====== |
| - | [[usage manual | Usage Manual]] | + | [[: |
| - | + anything | + | Anything |
wikify/template/project.1228127338.txt.gz · Last modified: 2008/12/01 10:28 by Durisian
