16th_fixed_polysequencer [2017/12/01 04:43] phatline [16th fixed PolySequencer] |
16th_fixed_polysequencer [2017/12/20 04:47] phatline [Code - C and HEX] |
Line 2: | Line 2: | ||
{{:phatline:16th_fixed_poly-test-setup.jpg?400 |}}\\ | {{:phatline:16th_fixed_poly-test-setup.jpg?400 |}}\\ | ||
{{:phatline:16th_fixed_poly-footboard.jpg?800 |}}\\ | {{:phatline:16th_fixed_poly-footboard.jpg?800 |}}\\ | ||
- | + | [[https://youtu.be/sXOMSEGNLTk|beta in action - youtube]] | |
===== Specs ?===== | ===== Specs ?===== | ||
**4 Midi-Channels: 1 2 3 4**\\ | **4 Midi-Channels: 1 2 3 4**\\ | ||
- | --2 Tracks a Channel\\ | + | --2 Tracks a Channel\\ |
- | --8 Notes-Chord a Track\\ | + | --8 Notes-Chord a Track\\ |
- | --each track has a dedicated and changeable loop-length from 16 to 256 Steps (example for 4-4)\\ | + | --each track has a dedicated and changeable loop-length from 16 to 512 Steps (example for 4-4)\\ |
- | --each Track can played single and booth tracks can be played simultan/in-dual\\ | + | --each Track can played single and booth tracks can be played simultan/in-dual\\ |
+ | --each Track record/playback PitchBend, the right one of a Track-Couple is the Pitchbend we hear \\ | ||
+ | --when the right one is muted & the left track is unmuted = the left tracks PitchBend is what we hear...\\ | ||
+ | --so you could play a chord @left-track, and while you record or play new notes left or right, both notes getting PitchBended by the right tracks Pitchbend\\ | ||
**Fixed Velocity @ 127**\\ | **Fixed Velocity @ 127**\\ | ||
- | --no Keyboard-Velocity-sense ([[Triggermatrix]] does the job of sensing drum trigger in order to re-trigger the moldy buffer\\ | + | --no Keyboard-Velocity-sense [[Triggermatrix]] does the job of sensing drum trigger in order to re-trigger the moldy buffer\\ |
**16th fixed note-trigger-rate**\\ | **16th fixed note-trigger-rate**\\ | ||
Line 19: | Line 21: | ||
--[[Triggermatrix]] does the job of melody-rythm-re-triggering}\\ | --[[Triggermatrix]] does the job of melody-rythm-re-triggering}\\ | ||
- | **512 Songs saved on SD-Card**\\ | + | **128 Songs saved on SD-Card**\\ |
--Load-able while playing - when the beat-structure is the same\\ | --Load-able while playing - when the beat-structure is the same\\ | ||
+ | --each song provide 4clips on each of 8tracks = 8x 4clips x128Songs = 8x512clips a track = 4096clips saved on SD-Card\\ | ||
+ | --so 4x | ||
===== the Midi-System-Setup ===== | ===== the Midi-System-Setup ===== | ||
Line 51: | Line 55: | ||
* M3 Distance-Stamps to mount the pcps\\ | * M3 Distance-Stamps to mount the pcps\\ | ||
* SD-Card\\ | * SD-Card\\ | ||
+ | {{:phatline:16th_fixed_poly-footboard-inside1.jpg?600 |}}\\ | ||
+ | {{:phatline:16th_fixed_poly-footboard-inside2.jpg?600 |}}\\ | ||
+ | {{:phatline:16th_fixed_poly-footboard-inside3.jpg?600 |}}\\ | ||
+ | ===== Code - C and HEX ===== | ||
+ | so when you have those things, upload {{:phatline:SEQ-Melody-Footboard.zip|the Code}}\\ | ||
+ | --a almost not working beta here {{:phatline:seq-melody-footboard-beta.zip|the beta}}\\ | ||
===== fabricated PCB-Version ===== | ===== fabricated PCB-Version ===== |
