16th_fixed_polysequencer [2017/12/18 21:30] phatline [Specs ?] |
16th_fixed_polysequencer [2017/12/18 21:35] phatline [Specs ?] |
Line 14: | Line 14: | ||
**Fixed Velocity @ 127**\\ | **Fixed Velocity @ 127**\\ | ||
- | --no Keyboard-Velocity-sense ([[Triggermatrix]] does the job of sensing drum trigger in order to re-trigger the moldy buffer\\ | + | --no Keyboard-Velocity-sense [[Triggermatrix]] does the job of sensing drum trigger in order to re-trigger the moldy buffer\\ |
**16th fixed note-trigger-rate**\\ | **16th fixed note-trigger-rate**\\ | ||
Line 21: | Line 21: | ||
--[[Triggermatrix]] does the job of melody-rythm-re-triggering}\\ | --[[Triggermatrix]] does the job of melody-rythm-re-triggering}\\ | ||
- | **512 Songs saved on SD-Card**\\ | + | **128 Songs saved on SD-Card**\\ |
--Load-able while playing - when the beat-structure is the same\\ | --Load-able while playing - when the beat-structure is the same\\ | ||
+ | --each song provide 4clips on each of 8tracks = 8x 4clips x128Songs = 8x512clips a track = 4096clips saved on SD-Card\\ | ||
+ | --so 4x | ||
===== the Midi-System-Setup ===== | ===== the Midi-System-Setup ===== |
