ac_ulr [2013/09/02 11:37] antichambre [Introduction] |
ac_ulr [2013/09/20 09:45] antichambre |
Line 8: | Line 8: | ||
The goal: | The goal: | ||
* 20mm diameter ring. | * 20mm diameter ring. | ||
- | * 32 matriced Leds on SR. | + | * 32 matriced bicolor Leds on SR with PWM support. |
- | * 26mm between 2 rings for 16 to fit in a 19" rack. | + | * Width<27mm between 2 rings for 16 pots or encoders to fit in a 19" rack. |
- | * For encoders and potentiometers 270° and 300°. | + | * Support encoders and potentiometers 270° and 300°. |
* Low profile for integration facility. | * Low profile for integration facility. | ||
+ | * No component on top side except leds. | ||
+ | How:\\ | ||
+ | I need to drive 32 leds, 4*8. The trick was to find a register which has 12 ouputs and compatble with SR line(DOUT). | ||
+ | The <wrap download>[[http://www.nxp.com/documents/data_sheet/HEF4894B.pdf|NXP HEF4894B]] | ||
+ | </wrap> was made for it, i's a 12-stage shift-and-store register, its operation is very similar to that of the 74HC595(serial I/O, serial clock, parallel load) except that it has a strobe input for PWM function.\\ | ||
Autocad design rendering:\\ | Autocad design rendering:\\ |
