This page is part of the [[mios_c_simulator_-_debugger]] **[[acsim_console_h|ACSim_console.h]]**\\ [[acsim_console_c|ACSim_console.c]]\\ [[acsim_toolbox_c|ACSim_toolbox.c]]\\ [[acsim_mios_h|ACSim_mios.h]]\\ [[acsim_mios_c|ACSim_mios.c]]\\ \\ <code c> /* * ACSim_console.c * v 0.0.5 * * 2006 April 06 Created by Michael Markert, http://www.audiocommander.de * mios simulator source for MIOS (c) by T. Klose, http://www.midibox.org * 2006 May 19 stryd_one, Added Windoze stuff * 2006 July 15 general rework, adapted name spaces and filenames, correct header implementation, * added MIOS_HLP, changed license to GNU GPL * */ /* * Released under GNU General Public License * http://www.gnu.org/licenses/gpl.html * * This program is free software; you can redistribute it and/or modify it under the terms * of the GNU General Public License as published by the Free Software Foundation * * YOU ARE ALLOWED TO COPY AND CHANGE * BUT YOU MUST RELEASE THE SOURCE TOO (UNDER GNU GPL) IF YOU RELEASE YOUR PRODUCT * YOU ARE NOT ALLOWED NOT USE IT WITHIN PROPRIETARY CLOSED-SOURCE PROJECTS */ #ifndef _ACSIM_CONSOLE_H #define _ACSIM_CONSOLE_H #include "main.h" // ***** DEFINES ***** // this is a very important define // if _DEBUG_C is defines, the current target is the simulator // use #ifdef _DEBUG_C to implement code ONLY for the simulator class! #define _DEBUG_C // OS selection // You must choose one of the below options to set the correct Operating System for the application #define _DEBUG_OS_WIN //#define _DEBUG_OS_MAC // adapt general debug settings #define DEBUG_VERBOSE 0 // adapt application related settings #ifdef LCD_1x16 #define DEBUG_LCD_LINES 1 #define DEBUG_LCD_SIZE 16 #elifdef LCD_2x8 #define DEBUG_LCD_LINES 2 #define DEBUG_LCD_SIZE 8 #elifdef LCD_2x16 #define DEBUG_LCD_LINES 2 #define DEBUG_LCD_SIZE 16 #elifdef LCD_2x40 #define DEBUG_LCD_LINES 2 #define DEBUG_LCD_SIZE 40 #elifdef LCD_4x16 #define DEBUG_LCD_LINES 4 #define DEBUG_LCD_SIZE 16 #else #define DEBUG_LCD_LINES 4 #define DEBUG_LCD_SIZE 20 #endif #define DEBUG_BANKSTICK_SIZE 32768 #define DEBUG_BANKSTICK_NUM 1 // Number of AIN-Lines, either write it here or define AIN_NUM in main.h #define DEBUG_AIN_NUM AIN_NUM // Number of Encoders, either write it here or define ENC_NUM in main.h #define DEBUG_ENC_NUM ENC_NUM // "default" Encoder # #define DEBUG_ENCODER 0 // DIN-Pin config #define DEBUG_BUTTON_OK 0 // BUTTON_OK #define DEBUG_BUTTON_INCREASE 0 // BUTTON_INCREASE #define DEBUG_BUTTON_DECREASE 0 // BUTTON_DECREASE #define DEBUG_BUTTON_AIN_PEDAL 0 // BUTTON_AIN_PEDAL #define DEBUG_PEDAL_PRESSED 1 // define __wparam (ignore on ACSim) #define __wparam // prototypes void runloop(int loopcount); int main(int argc, char **argv); #endif /* _ACSIM_CONSOLE_H */ </code>
