acsim_mios_c
This page is part of the mios_c_simulator_-_debugger
ACSim_console.h
ACSim_console.c
ACSim_toolbox.h
ACSim_toolbox.c
/* * ACSim_mios.c * v 0.0.5 * * 2006 April 06 Created by Michael Markert, http://www.audiocommander.de * mios simulator source for MIOS (c) by T. Klose, http://www.midibox.org * */ /* * Released under GNU General Public License * http://www.gnu.org/licenses/gpl.html * * This program is free software; you can redistribute it and/or modify it under the terms * of the GNU General Public License as published by the Free Software Foundation * * YOU ARE ALLOWED TO COPY AND CHANGE * BUT YOU MUST RELEASE THE SOURCE TOO (UNDER GNU GPL) IF YOU RELEASE YOUR PRODUCT * YOU ARE NOT ALLOWED NOT USE IT WITHIN PROPRIETARY CLOSED-SOURCE PROJECTS */ #import <Stdio.h> #import "ACSim_mios.h" #import "ACSim_toolbox.h" #pragma mark Globals // globals unsigned char debug_ain_lastPin; unsigned int debug_ain_value[32]; unsigned char debug_din_lastPin; unsigned char debug_din_value[32]; unsigned int debug_enc_value[32]; unsigned char debug_bankstick_ctrl = 0x00; // 1st Bankstick preselected debug_bankstick_t debug_bankstick[DEBUG_BANKSTICK_NUM]; // "pic18f452.h" __PORTCbits_t PORTCbits; __PORTDbits_t PORTDbits; mios_box_stat_t MIOS_BOX_STAT; // HLP unsigned char MIOS_PARAMETER1; unsigned char MIOS_PARAMETER2; unsigned char MIOS_PARAMETER3; #pragma mark MIOS_AIN // MIOS_AIN extern void MIOS_AIN_DeadbandSet(unsigned char deadband) { return; } extern void MIOS_AIN_Muxed(void) { return; } extern void MIOS_AIN_UnMuxed(void) { return; } extern void MIOS_AIN_NumberSet(unsigned char pots) { return; } extern unsigned char MIOS_AIN_Pin7bitGet(unsigned char pin) { debug_ain_lastPin = pin; // last ainValue is 10bit return debug_ain_value[pin] >> 3; } extern unsigned int MIOS_AIN_PinGet(unsigned char pin) { debug_ain_lastPin = pin; return debug_ain_value[pin]; } #pragma mark MIOS_DIN // MIOS_DIN extern unsigned char MIOS_DIN_PinGet(unsigned char pin) { debug_din_lastPin = pin; if(DEBUG_PEDAL_PRESSED && (pin == DEBUG_BUTTON_AIN_PEDAL)) { debug_din_value[pin] = 0; return 0; // Button pressed (0V) } else { return debug_din_value[pin]; } } #pragma mark MIOS_DOUT // MIOS_DOUT extern unsigned char MIOS_SRIO_NumberGet(void) { return 16; } extern void MIOS_SRIO_NumberSet(unsigned char number_sr) { return; } extern unsigned char MIOS_SRIO_TS_SensitivityGet(void) { return 0; } extern void MIOS_SRIO_TS_SensitivitySet(unsigned char update_frq) { return; } extern unsigned char MIOS_SRIO_UpdateFrqGet(void) { return 10; } extern void MIOS_SRIO_UpdateFrqSet(unsigned char update_frq) { return; } extern unsigned char MIOS_SRIO_DebounceGet(void) { return 32; } extern void MIOS_SRIO_DebounceSet(unsigned char debounce_value) { return; } #pragma mark MIOS_ENC extern void MIOS_ENC_Abs7bitAdd(unsigned char enc, char add) { if((debug_enc_value[enc] == 127) && (add > 0)) { debug_enc_value[enc] = 127; } else if((debug_enc_value[enc] == 0) && (add < 0)) { debug_enc_value[enc] = 0; } else { debug_enc_value[enc] += add; } return; } extern unsigned char MIOS_ENC_Abs7bitGet(unsigned char enc) { return debug_enc_value[enc]; } extern void MIOS_ENC_Abs7bitSet(unsigned char enc, unsigned char value) { debug_enc_value[enc] = value; } extern unsigned char MIOS_ENC_NumberGet(void) { return 32; } extern unsigned char MIOS_ENC_SpeedGet(unsigned char enc) { return 0x01; } extern void MIOS_ENC_SpeedSet(unsigned char enc, unsigned char mode, unsigned char parameter) { return; } #pragma mark MIOS_LCD // MIOS_LCD extern void MIOS_LCD_Clear(void) { printf("\n"); } extern void MIOS_LCD_Cmd(unsigned char cmd) { return; } extern unsigned char MIOS_LCD_CursorGet(void) { return 0; } extern void MIOS_LCD_CursorSet(unsigned char pos) { printf("\n**MIOS_LCD** 0x%x\t|", pos); } extern void MIOS_LCD_Data(unsigned char data) { return; } extern void MIOS_LCD_Init(void) { return; } extern void MIOS_LCD_PrintBCD1(unsigned char v) { printf("%1.1i",v); } extern void MIOS_LCD_PrintBCD2(unsigned char v) { printf("%2.2i",v); } extern void MIOS_LCD_PrintBCD3(unsigned char v) { printf("%3.3i",v); } extern void MIOS_LCD_PrintBCD4(unsigned int v) { printf("%i",v); } extern void MIOS_LCD_PrintBCD5(unsigned int v) { printf("%i",v); } extern void MIOS_LCD_PrintChar(unsigned char c) { switch(c) { case 0x00: printf("_(0)"); break; case 0x01: printf("_(1)"); break; case 0x02: printf("-(2)"); break; case 0x03: printf("-(3)"); break; case 0x04: printf("-(4)"); break; case 0x05: printf("-(5)"); break; case 0x06: printf("=(6)"); break; case 0x07: printf("=(7)"); break; default: printf("%c",c); } } extern void MIOS_LCD_PrintHex1(unsigned char h) { printf("%X",h); } extern void MIOS_LCD_PrintHex2(unsigned char h) { printf("%X",h); } extern void MIOS_LCD_PrintPreconfString(unsigned char len, code char *str[len]) { printf("%s",str); } extern void MIOS_LCD_PrintString(code char *str) { printf("%s|",str); } extern void MIOS_LCD_PrintCString(code char *str) { printf("%s|",str); } extern void MIOS_LCD_PrintMessage(code char *str) { printf("%s|",str); } extern void MIOS_LCD_MessageStart(unsigned char delay) { printf("\n**MIOS_LCD: Output Message delayed for %i ticks", delay); } extern void MIOS_LCD_MessageStop(void) { printf("\n**MIOS_LCD: Output Message stopped"); } extern void MIOS_CLCD_SpecialCharInit(code char c_table) { return; } extern void MIOS_CLCD_SpecialCharsInit(code unsigned char *c_table) { return; } #pragma mark MIOS_BANKSTICK // debug bankstick unsigned char debug_check_bankstick(unsigned int addr) { MIOS_BOX_STAT.BS_AVAILABLE = (DEBUG_BANKSTICK_NUM > 0 ? 1 : 0); if(! MIOS_BOX_STAT.BS_AVAILABLE) { printf("\n**MIOS_BANKSTICK: !!! ERROR !!! : NO BANKSTICK AVAILABLE!"); return 1; } if(addr > DEBUG_BANKSTICK_SIZE) { printf("\n**MIOS_BANKSTICK: !!! ERROR !!! : address overflow!"); //MIOS_BOX_STAT.BS_AVAILABLE = 0; // this is the default MIOS behavior on read error return 1; } return 0; // no error } // MIOS_BANKSTICK extern unsigned char MIOS_BANKSTICK_CtrlGet(void) { return debug_bankstick_ctrl; } extern void MIOS_BANKSTICK_CtrlSet(unsigned char ctrl) { debug_bankstick_ctrl = ctrl; } extern unsigned char MIOS_BANKSTICK_Read(unsigned int addr) { if(debug_check_bankstick(addr)) { return; } unsigned char buf = debug_bankstick[debug_bankstick_ctrl].buffer[addr]; if(DEBUG_VERBOSE) { printf("\n**MIOS_BANKSTICK_Read(%X): %X", addr, buf); } // clear MIOS_BOX_STAT.BS_AVAILABLE on error return buf; } extern unsigned char MIOS_BANKSTICK_ReadPage(unsigned int addr, unsigned char *buffer) { if(debug_check_bankstick(addr)) { return; } int i; for(i=0;i<64;i++) { buffer[i] = MIOS_BANKSTICK_Read(addr + i); } // print buffer printf("\n**MIOS_BANKSTICK_ReadPage at 0x%X \n", addr); //hexview(buffer, sizeof(buffer)); hexview(buffer, 64); // clear MIOS_BOX_STAT.BS_AVAILABLE on error return *buffer; // return bs_content in readBuffer } extern unsigned char MIOS_BANKSTICK_Write(unsigned int addr, unsigned char value) { if(debug_check_bankstick(addr)) { return; } debug_bankstick[debug_bankstick_ctrl].buffer[addr] = value; if(DEBUG_VERBOSE) { printf("\n**MIOS_BANKSTICK_Write(%X): %X", addr, value); } // errorcodes: 0x00: no error // 0x01: byte mismatch (write failed) -- only set if verify enabled // 0x02: BankStick not available return 0; // no error } extern unsigned char MIOS_BANKSTICK_WritePage(unsigned int addr, unsigned char *buffer) { if(debug_check_bankstick(addr)) { return; } int i; for(i=0;i<64;i++) { MIOS_BANKSTICK_Write((addr + i), buffer[i]); } // print buffer printf("\n**MIOS_BANKSTICK_WritePage at 0x%X \n", addr); //hexview(buffer, sizeof(buffer)); hexview(buffer, 64); // errorcodes: 0x00: no error // 0x01: byte mismatch (write failed) -- only set if verify enabled // 0x02: BankStick not available return 0; // no error } #pragma mark MIOS_MIDI // MIOS_MIDI extern void MIOS_MIDI_BeginStream(void) { printf("\n**MIOS_MIDI_BeginStream**"); } extern void MIOS_MIDI_TxBufferPut(unsigned char b) { printf("\n**MIOS_MIDI_TxBufferPut, %i", b); } extern void MIOS_MIDI_EndStream(void) { printf("\n**MIOS_MIDI_EndStream**"); } extern unsigned char MIOS_MIDI_MergerGet(void) { return 0; } // not yet supported! extern void MIOS_MIDI_MergerSet(unsigned char mode) { return; } // not yet supported! /* extern void MIOS_MIDI_DeviceIDAutoSet(void) __wparam; extern unsigned char MIOS_MIDI_DeviceIDGet(void) __wparam; extern void MIOS_MIDI_DeviceIDSet(unsigned char device_id) __wparam; extern void MIOS_MIDI_Init(void) __wparam; extern unsigned char MIOS_MIDI_InterfaceGet(void) __wparam; extern void MIOS_MIDI_InterfaceSet(unsigned char interface) __wparam; extern void MIOS_MIDI_InterfaceAutoSet(void) __wparam; extern unsigned char MIOS_MIDI_RxBufferFree(void) __wparam; extern unsigned char MIOS_MIDI_RxBufferGet(void) __wparam; extern void MIOS_MIDI_RxBufferPut(unsigned char b) __wparam; extern unsigned char MIOS_MIDI_RxBufferUsed(void) __wparam; extern void MIOS_MIDI_TxBufferFlush(void) __wparam; extern unsigned char MIOS_MIDI_TxBufferFree(void) __wparam; extern unsigned char MIOS_MIDI_TxBufferGet(void) __wparam; extern void MIOS_MIDI_TxBufferPut(unsigned char b) __wparam; extern unsigned char MIOS_MIDI_TxBufferUsed(void) __wparam; */ #pragma mark MIOS_TIMER // MIOS_TIMER extern void MIOS_TIMER_Init(unsigned char mode, unsigned int period) { return; } extern void MIOS_TIMER_Start(void) { return; } extern void MIOS_TIMER_Stop(void) { return; } extern void MIOS_TIMER_ReInit(unsigned char mode, unsigned int period) { return; } #pragma mark MIOS_IIC // MIOS_IIC extern void MIOS_IIC_Start(void) { printf("\n**MIOS_IIC_Start**"); } extern void MIOS_IIC_Stop(void) { printf("\n**MIOS_IIC_Stop**"); } extern unsigned char MIOS_IIC_ByteSend(unsigned char b) { printf("\n**MIOS_IIC_ByteSend: %x \t %i \t %c", b, b, b); return 1; } extern unsigned char MIOS_IIC_ByteReceive(void) { printf("\n**MIOS_IIC_ByteReceived**"); return 1; } extern void MIOS_IIC_AckSend(void) { printf("\n**MIOS_IIC_ACK sent**"); } extern void MIOS_IIC_NakSend(void) { printf("\n**MIOS_IIC_NAK sent**"); } extern void MIOS_IIC_CtrlSet(unsigned char ctrl){ return; } extern unsigned char MIOS_IIC_CtrlGet(void) { return 0; // not sure about this return value! } #pragma mark MIOS_HELP extern unsigned char MIOS_HLP_GetBitANDMask(unsigned char value) { switch(value) { case 0: return 0xFE; break; case 1: return 0xFD; break; case 2: return 0xFB; break; case 3: return 0xF7; break; case 4: return 0xEF; break; case 5: return 0xDF; break; case 6: return 0xBF; break; case 7: return 0x7F; break; default: return 0; break; } } extern unsigned char MIOS_HLP_GetBitORMask(unsigned char value) { switch(value) { case 0: return 0x1; break; case 1: return 0x2; break; case 2: return 0x4; break; case 3: return 0x8; break; case 4: return 0x10; break; case 5: return 0x20; break; case 6: return 0x40; break; case 7: return 0x80; break; default: return 0; break; } } extern unsigned char MIOS_HLP_16bitAddSaturate(char add_value, unsigned int *ptr, unsigned int max_value) { // saturate to 0 or MAX // returns 0 if saturated, 1 if in-/decreased int i = (int)(*ptr + add_value); if(i < 0) { *ptr = 0; return 0; } else if(i > (signed)max_value) { *ptr = (unsigned char)max_value; return 0; } else { *ptr = (unsigned char)i; return 1; } } extern void MIOS_HLP_Dec2BCD(unsigned int value) { // decimals to hex (eg 123456 to 0x12, 0x34, 0x56) MIOS_PARAMETER1 = 0x0; MIOS_PARAMETER2 = 0x0; MIOS_PARAMETER3 = 0x0; if(value > 999999) { printf("\nMIOS_HLP_Dec2BCD_ERROR: value exceeds 6 digits! ABORTING**"); return; } unsigned char a; unsigned char b; // get 100.000 a = (unsigned char)(value / 100000); b = (unsigned char)((value / 10000) - (a * 10)); MIOS_PARAMETER3 = (a << 4) + b; // get 1.000 value = value - (a * 100000 + b * 10000); a = (unsigned char)(value / 1000); b = (unsigned char)((value / 100) - (a * 10)); MIOS_PARAMETER2 = (a << 4) + b; // get 10 value = value - (a * 1000 + b * 100); a = (unsigned char)(value / 10); b = (unsigned char)(value - (a * 10)); MIOS_PARAMETER1 = (a << 4) + b; }
acsim_mios_c.1165327096.txt.gz · Last modified: 2007/01/17 00:23 (external edit)
