acsim_mios_h
Differences
Link to this comparison view
Both sides previous revision Previous revision
acsim_mios_h [2007/10/06 12:19]
stryd_one
acsim_mios_h [2007/11/17 16:47]
smashtv move acsim.zip to "acsim" namespace
Line 1: Line 1:
-This page is part of the [[mios_c_simulator_-_debugger]]
-[[acsim_console_h|ACSim_console.h]]\\
-[[acsim_console_c|ACSim_console.c]]\\
-**[[acsim_mios_h|ACSim_mios.h]]**\\
-[[acsim_mios_c|ACSim_mios.c]]\\
-[[acsim_toolbox_h|ACSim_toolbox.h]]\\
-[[acsim_toolbox_c|ACSim_toolbox.c]]\\
-[[acmididefines|ACMidiDefines.h]]\\
-This code is for viewing only and may not be up to date. You can download the files in a {{acsim.zip|.zip file here}}. If you make any updates, please send them to stryd_one and he will update the zip for you.
-<code c>
- ​* ​ ACSim_mios.h
- ​* ​ v 0.0.7
- ​* ​ 2006 April 06 Created by Michael Markert, http://​www.audiocommander.de
- ​* ​ mios simulator header for MIOS (c) by T. Klose, http://​www.midibox.org
- * Released under GNU General Public License
- * http://​www.gnu.org/​licenses/​gpl.html
- * This program is free software; you can redistribute it and/or modify it under the terms
- * of the GNU General Public License as published by the Free Software Foundation
- * YOU ARE ALLOWED TO COPY AND CHANGE ​
- * BUT YOU MUST RELEASE THE SOURCE TOO (UNDER GNU GPL) IF YOU RELEASE YOUR PRODUCT ​
- * YOU ARE NOT ALLOWED TO USE IT WITHIN PROPRIETARY CLOSED-SOURCE PROJECTS
-#ifndef _ACSIM_MIOS_H
-#define _ACSIM_MIOS_H
-#import <​Stdio.h>​
-#import "​ACSim_console.h"​
-#define __wparam  ​
-#define code const
-// MIOS definitions
-#define MIOS_MIDI_INTERFACE_COMMON 0x00
-#define MIOS_MIDI_INTERFACE_TO_HOST 0x01
-#define MIOS_MIDI_MERGER_DISABLED 0x00
-#define MIOS_MIDI_MERGER_ENABLED 0x01
-#define MIOS_MIDI_MERGER_MBLINK_EP 0x02
-#define MIOS_MIDI_MERGER_MBLINK_FP 0x03
-#define MIOS_ENC_SPEED_SLOW 0x00
-#define MIOS_ENC_SPEED_NORMAL 0x01
-#define MIOS_ENC_SPEED_FAST 0x02
-#define MIOS_LCD_TYPE_CLCD 0x00
-#define MIOS_LCD_TYPE_GLCD0 0x01
-#define MIOS_LCD_TYPE_GLCD1 0x02
-#define MIOS_LCD_TYPE_GLCD2 0x03
-#define MIOS_LCD_TYPE_GLCD3 0x04
-#define MIOS_LCD_TYPE_GLCD4 0x05
-#define MIOS_LCD_TYPE_MLCD 0x06
-#define MIOS_LCD_TYPE_GLCD_CUSTOM 0x07
-#define MIOS_GLCD_FONT 0x28fc
-// structures of the CFG and STAT bytes
-typedef union {
- struct {
- unsigned ALL:8;
- struct {
- unsigned LCD_TYPE:​3; ​ // selects LCD type
- unsigned USE_GLCD:​1; ​ // if 1, graphical LCD is connected
- unsigned MERGER:​1; ​   // if 1, MIDI merger is enabled
- unsigned MBLINK:​1; ​   // if 1, MIDIbox Link is enabled
- unsigned TO_HOST:​1; ​  // if 1, MIDI interface will run with 38400 baud instead of 31250
- unsigned FRQ_20MHz:​1;​ // if 1, it is assumed that the bux is running with 20 MHz, else with 40 MHz
-} mios_box_cfg0_t;​
-typedef union {
- struct {
- unsigned ALL:8;
- struct {
- unsigned BS_A:​3; ​           // A2..A0 of BankStick
- unsigned BS_DIS_VERIFY:​1; ​  // if 1, writes to the BankStick will not be verified
- unsigned IIC_STRETCH_CLK:​1;​ // if 1, IIC clock stretching enabled
-unsigned :1;
-unsigned :1;
-unsigned :1;
-} mios_box_cfg1_t;​
-typedef union {
- struct {
- unsigned ALL:8;
- struct {
- unsigned BS_AVAILABLE:​1; ​       // if 1, BankStick is available
- unsigned MBLINK_TUNNEL_PASS:​1; ​ // if 1, a MBLinked event will be tunnled
- unsigned SUSPEND_ALL:​1; ​        // if 1, all system and user tasks are suspended
- unsigned SUSPEND_USER:​1; ​       // if 1, all user tasks are suspended
- unsigned AUTOREPEAT:​1; ​         // if 1, start the auto-repeat handler
- unsigned MLCD_TRANSFER:​1; ​      // if 1, a transfer to the MLCD has been started
-unsigned :1;
-unsigned :1;
-} mios_box_stat_t;​
-// debug related structures
-typedef union {
- struct {
- unsigned ALL:8;
- struct {
- unsigned TIMER_ENABLED:​1;​
- unsigned free:7;
-} debug_user_timer_t;​
-// mios tables
-extern const unsigned char MIOS_MPROC_EVENT_TABLE[2*128];​
-extern const unsigned char MIOS_ENC_PIN_TABLE[2*64];​
-#pragma mark pic18f typedefs
-// "​pic18f452.h"​ typedefs
-typedef union {
- struct {
- unsigned RC0:1;
- unsigned RC1:1;
- unsigned RC2:1;
- unsigned RC3:1;
- unsigned RC4:1;
- unsigned RC5:1;
- unsigned RC6:1;
- unsigned RC7:1;
- struct {
- unsigned T1OSO:1;
- unsigned T1OSI:1;
- unsigned :1;
- unsigned SCK:1;
- unsigned SDI:1;
- unsigned SDO:1;
- unsigned TX:1;
- unsigned RX:1;
- struct {
- unsigned T1CKI:1;
- unsigned CCP2:1;
- unsigned CCP1:1;
- unsigned SCL:1;
- unsigned SDA:1;
- unsigned :1;
- unsigned CK:1;
- unsigned DT:1;
-} __PORTCbits_t;​
-typedef union {
- struct {
- unsigned RD0:1;
- unsigned RD1:1;
- unsigned RD2:1;
- unsigned RD3:1;
- unsigned RD4:1;
- unsigned RD5:1;
- unsigned RD6:1;
- unsigned RD7:1;
- struct {
- unsigned AD0:1;
- unsigned AD1:1;
- unsigned AD2:1;
- unsigned AD3:1;
- unsigned AD4:1;
- unsigned AD5:1;
- unsigned AD6:1;
- unsigned AD7:1;
-} __PORTDbits_t;​
-typedef union {
- struct {
- unsigned RBIF:1;
- unsigned INT0F:1;
- unsigned T0IF:1;
- unsigned RBIE:1;
- unsigned INT0E:1;
- unsigned T0IE:1;
- unsigned PEIE:1;
- unsigned GIE:1;
-} __INTCONbits_t;​
-#pragma mark debug typedefs
-// bankstick
-typedef struct {
- unsigned char buffer[DEBUG_BANKSTICK_SIZE];​
-} debug_bankstick_t;​
-#pragma mark mios globals
-// mios globals
-extern mios_box_stat_t MIOS_BOX_STAT;​
-// "​pic18f452.h"​
-extern __PORTCbits_t PORTCbits;​
-extern __PORTDbits_t PORTDbits;​
-extern __INTCONbits_t INTCONbits;​
-// HLP
-extern unsigned char MIOS_PARAMETER1;​
-extern unsigned char MIOS_PARAMETER2;​
-extern unsigned char MIOS_PARAMETER3;​
-#pragma mark debug globals
-// export globals
-extern debug_user_timer_t debug_user_timer;​
-extern unsigned char debug_ain_lastPin;​
-extern unsigned int debug_ain_value[32];​
-extern unsigned char debug_din_lastPin;​
-extern unsigned char debug_din_value[32];​
-extern unsigned int debug_enc_value[32];​
-extern unsigned char debug_bankstick_ctrl;​
-extern debug_bankstick_t debug_bankstick[DEBUG_BANKSTICK_NUM];​
-extern unsigned int debug_MIDI_byteNum;​
-extern unsigned int debug_IIC_byteNum;​
-#endif /* _ACSIM_MIOS_H */
-</​code>​
acsim_mios_h.txt ยท Last modified: 2007/11/17 16:47 by smashtv
