adding_buttons_for_bankstick_switching
Differences
Link to this comparison view
adding_buttons_for_bankstick_switching [2008/03/23 21:56]
adding_buttons_for_bankstick_switching [2008/03/23 21:56] (current)
Line 1: Line 1:
 +====== How to add bankstick UP/DOWN buttons to mbSID v2 ======
 +This is another draft. Actually it's just the source code that you'll need to add :D Make sure you've read the other tutorials that cover all the stuff needed to understand this one. This is not really a great way of achieving what we want, but it's good enough for now...
 +  * In app_defines.h you'll need to find some space (1 byte) for a variable we'll name "​BANK_STICK_NO"​. This variable will hold the selected bankstick.
 +  * In cs_menu_buttons.inc:​
 +<​code>​
 +CS_MENU_BUTTON_BankUp
 + ;; do nothing if button has been depressed
 + btfsc MIOS_PARAMETER2,​ 0
 + return
 + incf   ​ BANK_STICK_NO,​ W ; increment bank, load result into w
 + goto CS_MENU_BUTTON_AssignBank
 +CS_MENU_BUTTON_BankDown
 + return
 + decf  BANK_STICK_NO,​ W ; decrement bank, load result into w
 + ;; goto CS_MENU_BUTTON_AssignBank
 +CS_MENU_BUTTON_AssignBank
 + andlw ​  0x07 ; this keeps result from getting bigger than 7
 + movwf BANK_STICK_NO
 + movwf CS_MENU_SID_M_BANK
 + movff CS_MENU_SID_M_BANK,​ SID_BANK
 + ;; mask out '​sent'​ flag
 + bcf SID_PATCH,​ 7
 + call CS_MENU_EXEC_GoToMain
 + return
 +</​code>​
adding_buttons_for_bankstick_switching.txt ยท Last modified: 2008/03/23 21:56 (external edit)
