ain_4_board_parts_list
AIN_4 module
This is a simple way of scaling CVs (as might come from a modular) ready for an STM322F4 Core module.
Schematic
The circuit is a very simple series of two inverting amplifiers per channel. The first is a TL072 powered from +12/-12V, while the second is an MCP6002 powered from 3v3/0V (ground). It's possible to preset the ranges (see below) but it's probably more useful to use the associated Control Board.
BOM
Type Qty Value Package PartsNotes
resistors
20 49k9 0204/7R1, R2, R4, R5, R6, R7, R8, R10, R11, R12, R13, R14, R16, R17, R18, R19, R20, R22, R23, R24
4 30k 0204/7R3, R9, R15, R21nominal gain can be adjusted e.g. (22k/49.9k)*5V = 2.2V
capacitors
410p025×050C1, C3, C5, C7
9100n025×050C10, C12, C13, C14, C15, C16, C17, C18, C20remove 1 if powering from Core
310uelectrolytic 2,5-6C9, C11, C19remove 1 if powering from Core
4optional025×050C2, C4, C6, C8can use another e.g. 10pF cap here for more filtering
inductors
2BEAD5MML1, L2
ICs
2MCP6002PDIL08IC2, IC4sockets are recommended
2TL072PDIL08IC1, IC3sockets are recommended
Vreg
1optionalTO-220VR1remove if powering from Core
headers
7 1X02_SMALLJP1, JP2, JP3, JP4, JP5, JP6, JP7check board for headers as SIL strips of 3, 5 or 6
8 1X03_SMALLJP8, JP9, JP10, JP11, JP12, JP13, JP14, JP15
2 2*5 (shrouded)J1, J2
Assembly
ain_4_board_parts_list.1470842268.txt.gz ยท Last modified: 2016/08/10 15:17 by latigid_on
