ainser8_module [2016/08/04 09:30] psykhaze [Introduction] |
ainser8_module [2016/08/04 23:51] psykhaze [Introduction] |
Line 1: | Line 1: | ||
====== AINSER8 Module ====== | ====== AINSER8 Module ====== | ||
- | {{ :neonking:mbhp_ainser8.jpg?600 |}} | + | {{ :neonking:mbhp_ainser8.jpg?400 |}} |
- | MBHP_AINSER8 is a Reduced version of the MBHP_AINSER64 module without 1-to-8 multiplexers and on-board VR, and **//only supported by MIOS32!//** | + | MBHP_AINSER8 is a Reduced version of the MBHP_AINSER64 module without 1-to-8 multiplexers and on-board VR, and **//only supported by [[MIOS32]]!// |
- | **It is based on the 8-channel ADC MCP3208 from Microchip**. It can be used to scan pots and/or faders with 12bit resolution between 0 and 5V. | + | It is based on the 8-channel ADC MCP3208** from Microchip. It can be used to scan pots and/or faders with 12bit resolution between 0 and 5V.**The accuracy and especially the signal/noise ratio is much better compared to the internal ADCs of STM32** for insignificantly higher costs (around 3 EUR). |
- | **The accuracy and especially the signal/noise ratio is much better compared to the internal ADCs of STM32** for insignificantly higher costs (around 3 EUR). | ||
- | \\ | + | Another advantage is the **Improved Scalability**. While with the previous MBHP_AIN module the maximum number of scannable inputs was limited by the number of on-chip ADC channels, **the new approach allows to access multiple MBHP_AINSER64 and MBHP_AINSER8 modules from the same microcontroller.The ADC is accessed via SPI** (e.g. J19 of the MBHP_CORE_STM32F4 module). |
- | Another advantage is the **Improved Scalability**. While with the previous MBHP_AIN module the maximum number of scannable inputs was limited by the number of on-chip ADC channels, **the new approach allows to access multiple MBHP_AINSER64 and MBHP_AINSER8 modules from the same microcontroller**. | + | |
- | **The ADC is accessed via SPI** (e.g. J19 of the MBHP_CORE_STM32F4 module). | + | |
Line 24: | Line 20: | ||
- | Powering the module via USB (provided at J19 by the core module) is sufficient. It's recommended to use a "selfpowered" USB Hub like this one from Reichelt. It also decouples the power from the (noisy) PC supply, and allows to run the MIDIbox without a PC connection. | + | **Powering the module via USB (provided at J19 by the core module) is sufficient**. It's recommended to use a "selfpowered" USB Hub like this one from Reichelt. It also decouples the power from the (noisy) PC supply, and allows to run the MIDIbox without a PC connection. |
+ | ===== Parts List / Schematic ===== | ||
+ | See [[ainser8_board_parts_list|AINSER8 Parts List]] | ||
+ | * {{http://ucapps.de/mbhp/mbhp_ainser8.pdf|Schematic}}<sup>UCapps</sup> | ||
===== Inputs/ Outputs Port Table ===== | ===== Inputs/ Outputs Port Table ===== | ||
+ | ^ Port ^ Pins # ^ Description ^ | ||
+ | | J2 | 10 | Serial input which is usually connected to J19 of MBHP_CORE_STM32F4 module. | | ||
+ | | J3 | 10 | Serial output which could be used to chain multiple MBHP_AINSER* modules.**Please note: the standard AINSER driver for MIOS32 doesn't support this method!** Instead it expects that multiple modules are connected to J19 in parallel, and that they are using dedicated chip select lines (selected via jumper J4)! | | ||
+ | | J4 | 3 | A jumper has to be connected to this port to select the first or second chip select line of J2 for accessing the ADC. | | ||
+ | | J6 | 10 | 8 analog inputs and 5V (=Vd) / Ground (=Vs) connections.**Please note: all unused analog inputs have to be clamped to ground (Vss)**, otherwise your MIDIbox will send out a lot of random MIDI events | |
