antixfm [2016/07/14 17:42] psykhaze [Antix Midibox FM Build] |
antixfm [2016/07/14 17:48] psykhaze [Setup] |
Line 20: | Line 20: | ||
===== Setup ===== | ===== Setup ===== | ||
- | 1 core ,1 Din and 1 Dout populated with only three chips. The display is one of the very first hitachi that I bought in the late 90,Saved for this project. Some wiring with a label on every wire against any error | + | 1 PIC core ,1 Din and 1 Dout populated with only three chips. The display is one of the very first hitachi that I bought in the late 90,Saved for this project. Some wiring with a label on every wire against any error |
The power supply is made by me with PCB etching and a good quality transformer ( the capacitors are high quality with low SR from railway technology ) | The power supply is made by me with PCB etching and a good quality transformer ( the capacitors are high quality with low SR from railway technology ) | ||
{{::antix:pwr_supply.jpg?direct&400 |}} | {{::antix:pwr_supply.jpg?direct&400 |}} | ||
- | ===== Photos ===== | + | \\ |
+ | ===== Further Photos ===== | ||
+ | {{::antix:mbfm3.jpg?direct&800|}} | ||
+ | {{::antix:mbfm4.jpg?direct&800|}} | ||
+ | {{::antix:mbfm6.jpg?direct&800|}} | ||
+ | {{::antix:mbfm_comp3.jpg?direct&800|}} | ||
+ | {{::antix:mbfm_comp2.jpg?direct&800|}} | ||
+ | {{::antix:opl3.jpg?direct&800|}} |
