Both sides previous revision Previous revision | Last revision Both sides next revision | ||
arkade [2016/07/04 01:53] psykhaze [Features] |
Line 31: | Line 31: | ||
===== Features ===== | ===== Features ===== | ||
- | - for **__all the sensors__**, you can set : | + | * for **__all the sensors__**, you can set : |
* the midi channel | * the midi channel | ||
* the controller n° | * the controller n° | ||
Line 38: | Line 38: | ||
* a name (that will appear automatically when touched) | * a name (that will appear automatically when touched) | ||
- | - for **__the two ribbon controllers__**, you have two extra settings : | + | * for **__the two ribbon controllers__**, you have two extra settings : |
* mode (CC/note = will behave like a synth keyboard, generating notes on/off instead of continuous controller values) | * mode (CC/note = will behave like a synth keyboard, generating notes on/off instead of continuous controller values) | ||
* release (keep = last value kept after release / RTZ = return to zero after release) | * release (keep = last value kept after release / RTZ = return to zero after release) |
