audio_synthesis_integrated_circuit [2016/06/14 12:46] psykhaze [MIDIbox related] |
audio_synthesis_integrated_circuit [2016/06/14 19:37] psykhaze [Reference Datasheets] |
Line 2: | Line 2: | ||
{{ ::neonking:pdip_40_t.jpg?direct&200 |}} | {{ ::neonking:pdip_40_t.jpg?direct&200 |}} | ||
- | ===== Introduction ===== | ||
Most of the audio synthesis integrated circuits used in MIDIbox project are some Programmable Sound Generators. This means that you send binary data as input to have analog audio output | Most of the audio synthesis integrated circuits used in MIDIbox project are some Programmable Sound Generators. This means that you send binary data as input to have analog audio output | ||
- | ===== MIDIbox related ===== | + | ===== Reference Datasheets / Programming Manuals ===== |
- | * [[http://www.6502.org/documents/datasheets/mos/mos_6581_sid.pdf|MOS6581]] | + | * [[https://drive.google.com/open?id=0BzLvNo6FQZJscFJYaHFzLU15OUk|MOS6581]] |
* [[http://www.6502.org/documents/datasheets/mos/mos_6582_sid.pdf|MOS6582]] | * [[http://www.6502.org/documents/datasheets/mos/mos_6582_sid.pdf|MOS6582]] | ||
* [[http://map.grauw.nl/resources/sound/yamaha_ymf262.pdf|YMF262]] | * [[http://map.grauw.nl/resources/sound/yamaha_ymf262.pdf|YMF262]] |
