bandmaster [2018/10/06 11:02] antichambre [Bandmaster CS] |
bandmaster [2018/10/08 09:05] antichambre [BOM] |
Line 8: | Line 8: | ||
The Remote Control. | The Remote Control. | ||
==== Top ==== | ==== Top ==== | ||
- | {{ :antichambre:1809_bandmaster_cs_beta_top.png |}} | + | {{ :antichambre:1809_bandmaster_cs_beta_top.png?780 |}} |
==== Bottom ==== | ==== Bottom ==== | ||
- | {{ :antichambre:1809_bandmaster_cs_beta_bottom.png |}} | + | {{ :antichambre:1809_bandmaster_cs_beta_bottom.png?780 |}} |
==== BOM ==== | ==== BOM ==== | ||
- | version 1. | + | |
- | Mouser BOM:<wrap round todo 7%>toDo</wrap> | + | [[https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=2ff7704182|Mouser BOM version 1.]] |
+ | <wrap round todo 7%>to complete</wrap> | ||
^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^Other^Notes^ | ^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^Other^Notes^ | ||
^Resistors^^^^^^^^^ | ^Resistors^^^^^^^^^ | ||
- | |4 |22R 5% |0603 |R1, R2, R3, R4 | | | | | | | + | |4 |22R 5% |0603 |R1, R2, R3, R4 |[[https://www.mouser.fr/ProductDetail/Panasonic/ERJ-PA3J220V?qs=sGAEpiMZZMvdGkrng054t6%2fAfIpq60YDodYQkLMkIsXbHcv3Xk81uw%3d%3d|667-ERJ-PA3J220V ]] | | | | | |
- | |1 |680R 5% |0603 |R5 | | | | |Depends on Led | | + | |1 |120R 1% |1206 |R9 |[[https://www.mouser.fr/ProductDetail/Vishay/CRCW1206120RFKEAC?qs=sGAEpiMZZMvdGkrng054t8r8AhKhXLMmYrQwJH2ll8EzHZVcBuPHbA%3d%3d| |
- | ^PTC fuses, resettable thermistors^^^^^^^^^ | + | 71-CRCW1206120RFKEAC ]] | | | | | |
- | |1 |1206L150THWR|1206|F1|[[https://www.mouser.fr/ProductDetail/Littelfuse/1206L150THWR?qs=%2fha2pyFaduhlexFGoLte04X2tL%252bbW3Ma%252b9epP3LU68QBDZh6rRT18Q%3d%3d|576-1206L150THWR]] | | | | | | + | |8 |220R 5% |0603 |R17, R18, R19, R20, R21, R22, R23, R24 |[[https://www.mouser.fr/ProductDetail/ROHM-Semiconductor/ESR03EZPJ221?qs=sGAEpiMZZMvdGkrng054t67Efho1F8r6VYhbvNlxHb0%3d| |
+ | 755-ESR03EZPJ221 ]] | | | | | | ||
+ | |1 |470R 5% |0603 |R7 |[[https://www.mouser.fr/ProductDetail/ROHM-Semiconductor/ESR03EZPJ471?qs=sGAEpiMZZMvdGkrng054t67Efho1F8r6KOt1EakZPqs%3d|755-ESR03EZPJ471 ]] | | | | | | ||
+ | |3 |680R 5% |0603 |R5, R12, R13 |[[https://www.mouser.fr/ProductDetail/Panasonic/ERJ-PA3J681V?qs=sGAEpiMZZMvdGkrng054t6%2fAfIpq60YDGGtXI%252bjCSgEeBlnz3sOAbg%3d%3d| 667-ERJ-PA3J681V | ||
+ | ]] | | | |Depends on Led | | ||
+ | |5 |10K 5% |0603 |R6, R8, R14, R15, R16 |[[https://www.mouser.fr/ProductDetail/ROHM-Semiconductor/ESR03EZPJ103?qs=sGAEpiMZZMvdGkrng054t67Efho1F8r6e9okZoMz64k%3d| | ||
+ | 755-ESR03EZPJ103 ]] | | | | | | ||
+ | |2 |100K 5% |0603 |R10, R11 |[[https://www.mouser.fr/ProductDetail/ROHM-Semiconductor/ESR03EZPJ104?qs=sGAEpiMZZMvdGkrng054tywGjayRHxH2VJSU4tqJ%2fbOAC8vAO%2fF%252bEQ%3d%3d|755-ESR03EZPJ104 ]] | | | | | | ||
+ | ^Resistors Network^^^^^^^^^ | ||
+ | |3 |10K 5% |DIL5 |RN1, RN2, RN3 |[[https://www.mouser.fr/ProductDetail/858-L051S103LF|858-L051S103LF ]] | | | | | | ||
^Capacitors^^^^^^^^^ | ^Capacitors^^^^^^^^^ | ||
- | |1 |100n |0603|C2 | | | | | | | + | |9 |100n |0603|C2, C4, C6, C9, C10, C12, C13, C14, C15 |[[https://www.mouser.fr/ProductDetail/KEMET/C0603C104Z3VACTU?qs=sGAEpiMZZMs0AnBnWHyRQFqPnX0Olvco%252bYoiWDWTaEY%3d| 80-C0603C104Z3V |
- | |1 |4,7u |SMC_A|C1 | | | | | | | + | ]] | | | | | |
+ | |2 |1u |1210|C3, C5 |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/885012209047?qs=sGAEpiMZZMs0AnBnWHyRQEGbLOF2VP1irkndmZhuaTzcK1e5BJWtjg%3d%3d|710-885012209047]] | | | | | | ||
+ | |4 |4,7u Tantalum |SMC_A(1206)|C1, C7, C8, C11 |[[https://www.mouser.fr/ProductDetail/AVX/F931C475MAA?qs=sGAEpiMZZMuEN2agSAc2puC4lhRhLeolV32SDgrynyM%3d|647-F931C475MAA ]] | | | | | | ||
^ESD Suppressors / TVS Diodes ^^^^^^^^^ | ^ESD Suppressors / TVS Diodes ^^^^^^^^^ | ||
- | |7 |CG0603MLC-05E|0603|Z1, Z2, Z3, Z4, Z5, Z6, Z7|[[https://www.mouser.fr/ProductDetail/Bourns/CG0603MLC-05E?qs=%2fha2pyFaduj8GWc5RpRwWsoz%252bsBNDfM0b%2fMwO0m8cAS%252b28tb9AwLWQ%3d%3d|652-CG0603MLC-05E ]] | | | | | | + | |4 |CG0603MLC-05E|0603|Z1, Z2, Z3, Z4|[[https://www.mouser.fr/ProductDetail/Bourns/CG0603MLC-05E?qs=%2fha2pyFaduj8GWc5RpRwWsoz%252bsBNDfM0b%2fMwO0m8cAS%252b28tb9AwLWQ%3d%3d|652-CG0603MLC-05E ]] | | | | | |
+ | |1 |PESD1CAN |SOT23|Z5 |[[https://www.mouser.fr/ProductDetail/Nexperia/PESD1CAN215?qs=sGAEpiMZZMvxHShE6Whpu488MjWF3ynDhALtHXc07V8%3d|771-PESD1CAN-T/R ]] | | | | | | ||
^Ferrite Bead^^^^^^^^^ | ^Ferrite Bead^^^^^^^^^ | ||
|1 |BLM21|0805|L1 |[[https://www.mouser.fr/ProductDetail/Murata-Electronics/BLM21PG331SN1D?qs=%2fha2pyFaduh48AW%2fXw9aj3nquXPBFZV5Zyd%2f%2fy0ryyxfw3N8wCa1Fw%3d%3d|81-BLM21P331SG ]] | | | | | | |1 |BLM21|0805|L1 |[[https://www.mouser.fr/ProductDetail/Murata-Electronics/BLM21PG331SN1D?qs=%2fha2pyFaduh48AW%2fXw9aj3nquXPBFZV5Zyd%2f%2fy0ryyxfw3N8wCa1Fw%3d%3d|81-BLM21P331SG ]] | | | | | | ||
+ | ^Diodes^^^^^^^^^ | ||
+ | |51 |1N4148WS|SOD323-W|D1, D2, D3, D4, D5, D6, D7, D8, D9, D10, D11, D12, D13, D14, D15, D16, D17, D18, D19, D20, D21, D22, D23, D24, D25, D26, D27, D28, D29, D30, D31, D32, D33, D34, D35, D36, D37, D38, D39, D40, D41, D42, D43, D44, D45, D46, D47, D48, D49, D50, D51 |[[https://www.mouser.fr/ProductDetail/ON-Semiconductor-Fairchild/1N4148WS?qs=sGAEpiMZZMtoHjESLttvkr4bXZrJfFziTdC5C0Y1oek%3d|512-1N4148WS ]] | | | |Only if you use CAN without transceiver | | ||
^LEDs^^^^^^^^^ | ^LEDs^^^^^^^^^ | ||
- | |1 |--|0805 or THT |LED_OC | | | | |2x5mm rectangular THT | | + | |3 |--|THT |LED1, LED2, LED_OC | | | | |2x5mm rectangular THT | |
- | ^Transistor^^^^^^^^^ | + | ^OLED Screen^^^^^^^^^ |
- | |1 |FDN304P |SSOT-3 |Q1 |[[https://www.mouser.fr/ProductDetail/ON-Semiconductor-Fairchild/FDN304P?qs=sGAEpiMZZMshyDBzk1%2fWi6u8DDnmpUwtybEcsh7Clog%3d|512-FDN304P ]] | | | |P-Channel MOSFET| | + | |1 |ER-OLEDM032-1W| |OLED |[[https://www.buydisplay.com/default/serial-oled-module-price-3-2-inch-display-256x64-screens-white-on-black|ER-OLEDM032-1W]] | | | |buydisplay SSD1322 | |
^IC^^^^^^^^^ | ^IC^^^^^^^^^ | ||
- | |1 |STMPS2161STR|SOT23-5L|IC1 |[[https://www.mouser.fr/ProductDetail/STMicroelectronics/STMPS2161STR?qs=%2fha2pyFaduiAy%2fdT8k4k1fxaG8i6c%252bD3RLmjnwWa517tnLVTGOOraA%3d%3d|511-STMPS2161STR ]] | | | |Power Switch IC | | + | |1 |TPS2113APWR|SOT23-5L|IC1 |[[https://www.mouser.fr/ProductDetail/Texas-Instruments/TPS2113APWR?qs=sGAEpiMZZMuCmTIBzycWfArOWgm%252bsETdxNLLBukyKYc%3d|595-TPS2113APWR ]] | | | |Power Switch IC | |
+ | |1 |STMPS2161STR|SOT23-5L|IC2 |[[https://www.mouser.fr/ProductDetail/STMicroelectronics/STMPS2161STR?qs=%2fha2pyFaduiAy%2fdT8k4k1fxaG8i6c%252bD3RLmjnwWa517tnLVTGOOraA%3d%3d|511-STMPS2161STR ]] | | | |Power Switch IC | | ||
+ | |1 |TCAN1042GV|SOIC8|IC3 |[[https://www.mouser.fr/ProductDetail/Texas-Instruments/TCAN1042GVDRQ1?qs=sGAEpiMZZMsGqoCZrYwANq5ED54tVtBfM78HVPcr0sA%3d|595-TCAN1042GVDRQ1 ]] | | | |CAN tranceiver | | ||
+ | |2 |74HC595|TSSOP-16 |IC4, IC5 |[[https://www.mouser.fr/ProductDetail/Texas-Instruments/SN74HC595PWR?qs=sGAEpiMZZMtsbn1GaJysl3jBpe6P5FpF8hu51qPjpxQ%3d|595-SN74HC595PWR ]] | | | | | | ||
+ | |2 |74HC165|TSSOP-16 |IC6, IC7 |[[https://www.mouser.fr/ProductDetail/Texas-Instruments/SN74HC165PWR?qs=sGAEpiMZZMtsbn1GaJysl%252b133tPBKdjeGhg5tadf7q8%3d|595-SN74HC165PWR ]] | | | | | | ||
+ | ^Switches and Encoder^^^^^^^^^ | ||
+ | |2 |B3F-31xx |-- |USER, RESET |[[https://www.mouser.fr/ProductDetail/Omron-Electronics/B3F-3122?qs=sGAEpiMZZMsgGjVA3toVBLOYoGzF1EI%252baICPHiOMB%252bk%3d| | ||
+ | 653-B3F-3122 ]] | | | | | | ||
+ | |53 |MEC_5GTH or MEC_3FTH|-- |ALT, DST.1, DST.2, DST.3, DST.4, DST.5, DST.6, DST.7, DST.8, DST.9, DST.10, DST.11, DST.12, DST.13, DST.14, DST.15, DST.16, DST.ALL, DST.NONE, FUNC.1, FUNC.2, FUNC.3, FUNC.4, FUNC.5, FUNC.6, FUNC.7, FUNC.8, FUNC.9, FUNC.10, FUNC.11, FUNC.12, FUNC.13, FUNC.14, FUNC.15, SHIFT, SRC.1, SRC.2, SRC.3, SRC.4, SRC.5, SRC.6, SRC.7, SRC.8, SRC.9, SRC.10, SRC.11, SRC.12, SRC.13, SRC.14, SRC.15, SRC.16, SRC.ALL, SRC.NONE |[[https://www.mouser.fr/ProductDetail/MEC-Switches/5GTH92061?qs=sGAEpiMZZMsqIr59i2oRcpwS%252b9AUZWOYBzdN2G47qt4%3d| | ||
+ | 642-5GTH92061 ]] or[[https://www.mouser.fr/ProductDetail/MEC-Switches/3FTH9Q?qs=sGAEpiMZZMsqIr59i2oRcuFmFOrf4z6uJNe5cjfqmCw%3d| | ||
+ | 642-3FTH9Q ]] | | | |+ 3mm leds for 3FTH | | ||
+ | |1 |PEC12R |-- |ENC |[[https://www.mouser.fr/ProductDetail/Bourns/PEC12R-4217F-S0024?qs=sGAEpiMZZMsWp46O%252bq11WUFm4YUtE9euN%2fVzju3YmO4%3d| | ||
+ | 652-PEC12R-4217F-S24 ]] | | | | | | ||
^Connectors^^^^^^^^^ | ^Connectors^^^^^^^^^ | ||
- | |1 |mini-USB |THT |MINI-USB |[[https://www.mouser.fr/ProductDetail/TE-Connectivity/1734510-1?qs=sGAEpiMZZMulM8LPOQ%252byk5iMqoToDEs%2fWOccw2Kf2Ys%3d|571-1734510-1]] | | | | | | ||
|1 |USB-B |THT |USB-B |[[https://www.mouser.fr/ProductDetail/538-67068-8000|538-67068-8000 ]] | | | | | | |1 |USB-B |THT |USB-B |[[https://www.mouser.fr/ProductDetail/538-67068-8000|538-67068-8000 ]] | | | | | | ||
- | |1 |USB-A |THT |MINI-A |[[https://www.mouser.fr/ProductDetail/538-48204-0001|538-48204-0001]] | | | | | | + | |1 |USB-A |THT |USB-A |[[https://www.mouser.fr/ProductDetail/538-48204-0001|538-48204-0001]] | | | | | |
- | |1 |micro-match 2x4 |Female|J2A |[[https://www.mouser.fr/ProductDetail/TE-Connectivity/7-215079-8?qs=sGAEpiMZZMs%252bGHln7q6pm48SVpWlpfsEUiVE5fgbiD4%3d|571-7-215079-8 ]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/2178710-8?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8%2fCQlcYGYnC2hwh1bE9lC1w%3d%3d|571-2178710-8 (value line)]] | | | | | | + | |1 |RJE0166201 |single RJ11 6p6c |MCAN |[[https://www.mouser.fr/ProductDetail/Amphenol-Commercial-Products/RJE01-662-01?qs=sGAEpiMZZMvQhAhQbXdbBt6WycxQSKiVmnF7biEXLv8%3d|523-RJE01-662-01 ]] | | | | | |
- | |1 |micro-match 2x6 |Female|J1A |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215079-2?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg1R8%252bHzdf0ck%3d|571-8-215079-2]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-2?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8Bh9SlB9BUSeJ3BKKERN%252bmg%3d%3d|571-1-2178710-2 (value line)]] | | | || | + | |2 |micro-match 2x5 |Female |J8/9A, J15A |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/1-215079-0?qs=sGAEpiMZZMvlX3nhDDO4AD0YxAKLygYct7VkIBsEv0I%3d| |
+ | 571-12150790 ]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-0?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8toxxH7bCeDjvZhYFCVsCFg%3d%3d|571-1-2178710-0(value line)]] | | | | | | ||
+ | |2 |micro-match 2x5 |IDC|J8/9B, J15B |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215570-0?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg0iDJ6yhwCXo%3d|571-8-215570-0 ]] | | | |Paddle board| | ||
+ | |1 |DM3AT-SF-PEJM5 |Socket |micro-SD |[[https://www.mouser.fr/ProductDetail/Hirose-Connector/DM3AT-SF-PEJM5?qs=sGAEpiMZZMuJakaoiLiBpvjg2IzEXJkOoUNaxaL8lrc%3d|571-8-215079-4 ]] | | | |with push-push | | ||
^Others ^^^^^^^^^ | ^Others ^^^^^^^^^ | ||
|2 |Screw terminal |-- |-- |[[https://www.mouser.fr/ProductDetail/534-7790|534-7790 ]] | | | | | | |2 |Screw terminal |-- |-- |[[https://www.mouser.fr/ProductDetail/534-7790|534-7790 ]] | | | | | |
