c_tips_and_tricks_for_pic_programming
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
c_tips_and_tricks_for_pic_programming [2006/10/09 21:26]
audiocommander
c_tips_and_tricks_for_pic_programming [2011/09/15 07:14] (current)
ichaljhe
Line 1: Line 1:
-====== ​C Variables ​======+====== ​Arithmetic Calculations ​======
-  * Declaring ​[[http://en.wikipedia.org/wiki/Variable|variable]] as type 'const' will cause the [[http://en.wikipedia.org/wiki/Compiler|compiler]] to store the variable in the PIC's program ​[[http://en.wikipedia.org/wiki/Flash_memory|flash memory]]not the [[http://​en.wikipedia.org/​wiki/​Static_random_access_memory|SRAM]].+  * Avoid using **multiplications** and **divisions** whenever possible. These complex mathmatic calculations need lot processing power and (what'​s even worser) a huge library to be compiled at all.
 +  * If you need to multiply with and divide through even numbers like 2, 4, 8, 16, 32 ... you can make use of the bitshifting operators ">>"​ and "<<"​ <code c>
 +unsigned char c;
 +c = 12 >> 1;  ​// c is 6 (division through 2)
 +c = 12 >> 2;  // c is 3 (division through 4)
 +c = 12 << 1;  // c is 24 (multiplication by 2)
 +c = 12 << 2;  // c is 48 (mulitplication by 4)
 +c = 1023 >> 3; //  c is 127 (10bit to 7bit ;)
 +</​code>​
 +  * There's an excellent thread in the forum that discusses bitoperations: ​http://www.midibox.org/forum/index.php?​topic=6981.0
 +  * The [[http://www.midibox.org/forum/index.php/​topic,​9666.msg73781.html#​msg73781|Re: Scan Matrix extended : VOIRINOV]] thread has an explanation of what the declaration of the bitfield is all about.
 +  * If this is not enough, you could search for ASM optimized custom functions. You'll find some in code examples of TK, the [[ACSensorizer]] and a lot of PIC-Specialized Webpages – or of course the forum.
-  * Adding the keyword '​[[http://​en.wikipedia.org/​wiki/​Volatile_variable|volatile]]'​ to [[http://en.wikipedia.org/​wiki/​Variable|variable]] is a good idea when this variable can be changed or altered outside the sourcefile that declared this variable.+==== MIOS LIBSDCC Library ====
 +If that still is not enough or you have no time and lot of processing power space available on your PIC, you can include the **libsdcc library**Using the new MIOS GPUtils structure, ​this will be included automatically as required.
 +When using the library, sometimes the compiler will optimise multiplications to bitshifts (as demonstrated above) automatically. You can check the output files to see if this has occurred, but it is recommended to code the bitshifts manually, to be sure.
 +==== Bitfields, Unions & Structs ====
 +  * Avoid using huge int- or char-arrays when you just need to store some ON/OFF values. Use a bitfield instead
 +<code c>
 +// define the bitfield
 +typedef union {
 + struct {
 + unsigned ALL:​8; ​   // by calling something.ALL,​ you get the whole bitfield as 8-bit number
 + struct {
 + unsigned led1:​1; ​  // by calling something.led1 you get one bit-state (1 or 0)
 + unsigned led2:1;
 + unsigned led3:1;
 + unsigned led4:1;
 + unsigned free:4;
 +} something_t;​
 +// declare var
 +something_t something;
 +// set bits
 +something.led1 = 1;
 +something.led3 = 0;
 +// get number
 +mynum = something.ALL;​
 +</​code>​
 +>> It has been confirmed with recent versions of SDCC, that bitfields are not limited to 8bits as was previously expected.
 ====== C Functions ====== ====== C Functions ======
Line 19: Line 69:
   * [[How to mix C and ASM]]   * [[How to mix C and ASM]]
 +  * [[Compiled C Code Size]]
 +====== C Variables ======
 +  * Declaring a [[http://​en.wikipedia.org/​wiki/​Variable|variable]] as type '​const'​ will cause the [[http://​en.wikipedia.org/​wiki/​Compiler|compiler]] to store the variable in the PIC's program [[http://​en.wikipedia.org/​wiki/​Flash_memory|flash memory]], not the [[http://​en.wikipedia.org/​wiki/​Static_random_access_memory|SRAM]].
 +  * Adding the keyword '​[[http://​en.wikipedia.org/​wiki/​Volatile_variable|volatile]]'​ to a [[http://​en.wikipedia.org/​wiki/​Variable|variable]] is a good idea when this variable can be changed or altered outside the sourcefile that declared this variable.
 +  * Always use '​unsigned'​ if you are sure you don't need negative values. Although the default is an unsigned char, it's not always clear how C treats a '​char'​ (signed: -128 to 127; unsigned: 0 to 255), so it's better to be clear here.
 ====== SDCC Bugs/​Workarounds ====== ====== SDCC Bugs/​Workarounds ======
 Some of these bugs have first been described in a [[http://​www.midibox.org/​forum/​index.php?​topic=7463.msg50464#​msg50464|german thread in the forum]]. Some of these bugs have first been described in a [[http://​www.midibox.org/​forum/​index.php?​topic=7463.msg50464#​msg50464|german thread in the forum]].
Line 28: Line 90:
-===== Array Access ​===== +
-Sometimes the transfer of an array between modules does not work properly, e.g. file 1: <code c>+==== Array Access ====
 +Sometimes the transfer of an array between modules does not work properly, e.g. file 1:
 +<code c>
 unsigned char MIDIValues[8];​ unsigned char MIDIValues[8];​
-</​code>​ file 2: <code c>+</​code> ​
 +file 2:
 +<code c>
 MIOS_MIDI_TxBufferPut(MIDIValues[1]);​ MIOS_MIDI_TxBufferPut(MIDIValues[1]);​
-</​code> ​ Instead, you need to do something like <code c> +</​code>  ​
-unsigend ​char value = MIDIValues[1];​ //explicite ​temp variable +Instead, you need to do something like
-MIOS_MIDI_TxBufferPut(value);</​code>​+<code c>
 +unsigned ​char value = MIDIValues[1];​ //explicit ​temp variable
 +MIOS_MIDI_TxBufferPut(value);​
 +</​code>​
 +In most cases, adding parenthesis around your index variable has the same effect (see tip further down)
 +<code c>
 +MIOS_MIDI_TxBufferPut((MIDIValues[1]));​
 +</​code>​
-===== Large Arrays ​===== +
-Arrays with more than 256 elements will produce compile (in fact linker) errors:+==== Large Arrays ====
 +Arrays with more than 256 bytes of elements will produce compile (in fact linker) errors:
 <code c> <code c>
 unsigned char myArray[256];​ // will work unsigned char myArray[256];​ // will work
Line 46: Line 120:
 unsigned char myArray[64][4];​ // will work unsigned char myArray[64][4];​ // will work
 unsigned char myArray[64][5];​ // will not be linked! unsigned char myArray[64][5];​ // will not be linked!
 +unsigned int myArray[128];​ // will work
 +unsigned int myArray[129];​ // will not be linked!
 </​code>​ </​code>​
-Thanks to [[http://​www.midibox.org/​forum/​index.php?​topic=6814.msg43501#​msg43501|Thomas]] for testing some workarounds with multiple single-dimensional arrays:
-<code c>
-//instead of myArray[2][4][256];​
-unsigned char myArray00[256]; ​
-unsigned char myArray01[256]; ​
-unsigned char myArray02[256]; ​
-unsigned char myArray03[256]; ​
-unsigned char myArray10[256]; ​
-unsigned char myArray11[256]; ​
-unsigned char myArray12[256]; ​
-unsigned char myArray13[256]; ​
-// possible solutions:​ +This is due to the fact that the PIC's RAM has been segmented into 256-byte banks in the linker script, and an array'​s contents may not span across more than one bank.
-// ----------- version ​one ---------- +
-unsigned char otherArray[2];​ //to prevent contants that will be optimized +
-unsigned char myArray[3][4];​  +
-myArray[otherArray[0]][otherArray[1]];​ +
-// ----------- version two ---------- +The linker script can be modified to work around the 256-byte limitation by creating larger banks, as per the [[using_pic18f4620#​linker_script|Linker Script]] and [[using_pic18f4620#​application_code|Application Code]] tips on the 4620 page.
-unsigned char otherArray[2]; //to prevent contants that will be optimized +
-unsigned char myArray[12];  +
-myArray[otherArray[0]*3 + otherArray[1]]; +
-// ----------- version three ---------- +Thanks to Thomas for [[http://www.midibox.org/​forum/​index.php?​topic=6814.msg43501#​msg43501|testing some workarounds with multiple single-dimensional arrays]]. These methods would be recommended if possible.
-unsigned char myArray[3][4];  +
-myArray[1][2];  +\\
-// ---------------------------------+==== Bit Copy Operations ====
 +There is potential trouble with bit copy operations (See [[http://www.midibox.org/​forum/​index.php?​topic=7925.msg54675#​msg54675|this posting]]). Instead of
 +<code c>
 +  app_flags.SRAM_CARD_STATUS = PORTEbits.RE2;
 </​code>​ </​code>​
-Version two produces only 2/3 of the assembler statements of version one. \\ +you should use
-Version three (with constantswill be optimized to myArray[5].+<code c>
 +  ifPORTEbits.RE2 ​)
 +    app_flags.SRAM_CARD_STATUS = 1;
 +  }else{
 +    app_flags.SRAM_CARD_STATUS = 0;
 +</​code>​
 +It is less elegant, but it works safely.
-===== Parenthesis ​=====+==== Parenthesis ====
 Always use parenthesis around expressions like <code c>​myarray[a+b];</​code>​ instead use <code c>​myarray[(a+b)];</​code>​ Always use parenthesis around expressions like <code c>​myarray[a+b];</​code>​ instead use <code c>​myarray[(a+b)];</​code>​
-===== Preprocessor #ifs =====+==== Preprocessor #ifs ====
 Avoid #ifdef and #if preprocessor-statements wrapped around declarations and function prototypes. Even if the preprocessor'​s #if statement is true (eg defined as '​1'​),​ any access to it's vars and functions from outside these wrapped statements produce a compile-warning:​ <code c> Avoid #ifdef and #if preprocessor-statements wrapped around declarations and function prototypes. Even if the preprocessor'​s #if statement is true (eg defined as '​1'​),​ any access to it's vars and functions from outside these wrapped statements produce a compile-warning:​ <code c>
 #define TEST 1 #define TEST 1
Line 100: Line 166:
 </​code>​ </​code>​
-===== Zero Compare ​===== +==== Zero Compare ====
-Avoid comparisons of ''​unsigned char''​ with ''​0'',​ e.g. <code c>+Avoid comparisons of ''​unsigned char''​ with ''​0'',​ e.g.
 +<code c>
 unsigned char i; unsigned char i;
    for (i = 0; i < 0; i+ü) {    for (i = 0; i < 0; i+ü) {
-      //body +      // body
-   ​} ​ </​code>​ ''​0''​ could be a constant that was defined using ''#​define'',​ e.g. the number of motorized faders. But you have no motorized faders... The main problem consists in the fact that your code depends on what else is done around the comparison or in the body. This provokes completely erratic behaviour.+   }
 +</​code>​
 +''​0''​ could be a constant that was defined using ''#​define'',​ e.g. the number of motorized faders. But you have no motorized faders... The main problem consists in the fact that your code depends on what else is done around the comparison or in the body. This provokes completely erratic behaviour.
 +==== Stack Size ====
 +[[http://​www.midibox.org/​forum/​index.php?​topic=7687.msg52402#​msg52402|TK says:]]\\
 +The stack boundaries are defined in the file header of mios_wrapper/​mios_wrapper.asm:​
 +<code c>
 +; the upper boundary of the stacks are defined here
 +; customize the values for your needs
 +#ifndef STACK_HEAD
 +#define STACK_HEAD 0x37f
 +#endif
 +#ifndef STACK_IRQ_HEAD
 +#define STACK_IRQ_HEAD 0x33f
 +#endif
 +</​code>​
 +The default setup is 64 bytes for main tasks, 64 bytes for interrupt tasks. (stack pointer is counted down, there is no collision control to save runtime)
 +Since a PIC18F4620 has enough memory, you could use two 256 bytes stacks located at the upper RAM pages:
 +<​code>​
 +#define STACK_HEAD 0xeff
 +#define STACK_IRQ_HEAD 0xdff
 +</​code>​
 +this should relax the situation.
 +Note that the appr. memory area (0xd00-0xeff) should be reserved in the projekt.lkr file
 +Note that stacks greater than 256 bytes will not work with SDCC at present. [[http://​wemelt.com/​ipaymu-com-pembayaran-online-indonesia/​|iPaymu.com Pembayaran Online Indonesia]]
c_tips_and_tricks_for_pic_programming.1160429162.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
