cc-looper [2018/10/10 00:50] phatline |
cc-looper [2020/03/31 14:04] phatline [Building] |
Line 41: | Line 41: | ||
====== Building ====== | ====== Building ====== | ||
- | {{:phatline:CCL-sheme.png?500|}}\\ | ||
{{:phatline:CCL-pcb.png?500|}}\\ | {{:phatline:CCL-pcb.png?500|}}\\ | ||
{{:phatline:CCL-pcb-3dfront.png?500|}}\\ | {{:phatline:CCL-pcb-3dfront.png?500|}}\\ | ||
+ | {{:phatline:CCL-PCB-Top-Part-Position.png?500|}}\\ | ||
+ | {{:phatline:CCL-PCB-Back-Part-Position.png?500|}}\\ | ||
+ | {{:phatline:CCL-Dipcore-Pinout.png?900|}}\\ | ||
+ | {{:phatline:screenie.jpg?900|}}\\ | ||
+ | {{:phatline:ccl-6n138.jpg?900|}}\\ | ||
+ | {{:phatline:ccl-schema-proto.jpg?900|}}\\ | ||
+ | {{:phatline:ccl-schema-verbessert.jpg?900|}}\\ | ||
+ | {{:phatline:ccl-pcb-dt-led.png?500|}}\\ | ||
==== Frontpanel ==== | ==== Frontpanel ==== | ||
Line 51: | Line 59: | ||
- | ===== BOM ===== | + | ===== BOM ===== |
+ | ^Ref ^Qty ^Value ^Footprint ^MouserPart ^Link | ||
+ | |C1 – C7 |7 |100nF |0603 Capacitor |81-GRM33C71C104ME14D |[[https://www.mouser.at/ProductDetail/Murata-Electronics/GRM033C71C104ME14D?qs=sGAEpiMZZMs0AnBnWHyRQC2E6Mcmylam1hDr6SmNpQA61PNjrYjJhw%3d%3d|Mouser]] |end | ||
+ | |Rec--1 – Rec—4, UI--5 UI—4, led1, -1 -2 -3 -4 |11 |REC, LED, beat, CC-IN, |0603 LED |630-ASMT-RR45-AQ902 |[[https://www.mouser.at/ProductDetail/Broadcom-Avago/ASMT-RR45-AQ902?qs=sGAEpiMZZMseGfSY3csMkdPLvDBdRu8er4Ntaxf%252bO0Q%3d|Mouser]] |end | ||
+ | |1-16 (LED-BAR) |64 |bar |0603 LED |755-SMLEN3WBC8W1 |[[https://www.mouser.at/ProductDetail/ROHM-Semiconductor/SMLEN3WBC8W1?qs=sGAEpiMZZMseGfSY3csMkdgyOOAg6kv2ux0eqzFsX0CYFpgTajV5iA%3d%3d|Mouser]] |end | ||
+ | |D64 D65 |2 |1N-4148 |1206 Diode |833-1N4148W-TP |[[https://www.mouser.at/ProductDetail/Micro-Commercial-Components-MCC/1N4148W-TP?qs=sGAEpiMZZMtoHjESLttvkgpLF%252bwYSnVUwcBJAIiGaSw%3d|Mouser]] |end | ||
+ | |PTC1 |1 |Thermistor_PTC |1206 Resistor |576-1206L150THWR |[[https://www.mouser.at/ProductDetail/Littelfuse/1206L150THWR?qs=%2fha2pyFaduhlexFGoLte04X2tL%252bbW3Ma%252b9epP3LU68QBDZh6rRT18Q%3d%3d|Mouser]] |end | ||
+ | |R1, R2, R19 – R34 |18 |10K |1206 Resistor |603-AC0603FR-0710KL |[[https://www.mouser.at/ProductDetail/Yageo/AC0603FR-0710KL?qs=sGAEpiMZZMtlubZbdhIBIOG3KwTtqrl%2fm2zcUhmU2Sg%3d|Mouser]] |end | ||
+ | |R3 R5 R6 R7 R8 |5 |47 |1206 Resistor |603-RC0603FR-0747RL |[[https://www.mouser.at/ProductDetail/Yageo/RC0603FR-0747RL?qs=sGAEpiMZZMtlubZbdhIBIItYu4jZFrq8L5DEb7osJzY%3d|Mouser]] |end | ||
+ | |R9-R14, R36, R37 |8 |220 |1206 Resistor |603-RC0603FR-07220RL |[[https://www.mouser.at/ProductDetail/Yageo/RC0603FR-07220RL?qs=sGAEpiMZZMtlubZbdhIBIPpBVm91En7nA%2f1f2dcQDck%3d|Mouser]] |end | ||
+ | |R15 R16 |2 |1K |1206 Resistor |603-RC0603JR-071KL |[[https://www.mouser.at/ProductDetail/Yageo/RC0603JR-071KL?qs=sGAEpiMZZMtlubZbdhIBIAVdtiC5pVGKZfRlvR01bds%3d|Mouser]] |end | ||
+ | |R17 R18 |2 |4K7 |1206 Resistor |603-RC0603FR-074K7L |[[https://www.mouser.at/ProductDetail/Yageo/RC0603FR-074K7L?qs=sGAEpiMZZMtlubZbdhIBIItYu4jZFrq8L%2f7dpOVyqQA%3d|Mouser]] |end | ||
+ | |OUT1 |1 |Midi |DIN-8-SDF-80J |490-SDF-80J |[[https://www.mouser.at/ProductDetail/CUI/SDF-80J?qs=%2fha2pyFaduhSnV%252bWd1R6r7bGdUcvMTnY0cpLjk72NmbDw9NYb3x3SQ%3d%3d|Mouser]] |end | ||
+ | |M1 |1 |DIPCORE32_CMPNT_48P|517-929870-01-20-RA |DIP-40 |[[https://www.mouser.at/ProductDetail/517-929870-01-20-RA|Mouser]] |end | ||
+ | |S8 |1 |Shift |DT6 |611-D6R00F1LFS |[[https://www.mouser.at/ProductDetail/CK/D6R00F1LFS?qs=sGAEpiMZZMvxtGF7dlGNpmmAS%252bR8oK0rL60DZ%2fOhaRU%3d|Mouser]] |end | ||
+ | |S1 – S4 |1 |Part1 |611-SERWHAUOA |DTL2-1-LED |[[https://www.mouser.at/ProductDetail/?qs=Tr3lMbyRyKmNY3meBb4M6Q%3d%3d|Mouser]] |end | ||
+ | |S5 – S7, S9 – S10 |6 |X,C,V,Len,Pre,Tac |611-SERRDAUOA |DTL2-1-NO-LED |[[https://www.mouser.at/ProductDetail/?qs=xWNScUPc28qopt8OzNAdDQ%3d%3d|Mouser]] |end | ||
+ | |ENC1 |1 |ENC_BOURNS_PEC11 |ENC_BOURNS_PEC11+SW |652-PEC11R-4215F-S24 |[[https://www.mouser.at/ProductDetail/Bourns/PEC11R-4215F-S0024?qs=sGAEpiMZZMsWp46O%252bq11WUFm4YUtE9euwxV%252b4orks98%3d|Mouser]] |end | ||
+ | |IN1 IN2 |2 |Midi |Midi-Socket-MAB5SH-DIN-5|566-MAB5SH |[[https://www.mouser.at/ProductDetail/Lumberg-Automation-Hirschmann/MAB-5-SH?qs=%2fha2pyFadugsfwapFJjt9E5ipSyTnvvOqCTvH0Md5SI%3d|Mouser]] |end | ||
+ | |Foot1 |1 |Pin |PINHEAD-1x02_2.54mm | ||
+ | |J2 |1 |BootLoad |PINHEAD-1x02_2.54mm | ||
+ | |AIN1 |1 |PIN |PINHEAD-2x03_2.54mm | ||
+ | |U1 U2 |2 |6N136 |SMDIP-8_W11.48mm |782-6N136-X009 |[[https://www.mouser.at/ProductDetail/Vishay-Semiconductors/6N136-X009?qs=sGAEpiMZZMtIHXa%252bTo%2fr2UM1h%2fJ6CDzN|Mouser]] |end | ||
+ | |-595 |3 |74HC595 |SO-16-N |621-74AHC595S16-13 |[[https://www.mouser.at/ProductDetail/Diodes-Incorporated/74AHC595S16-13?qs=sGAEpiMZZMtsbn1GaJysl7ow%2f10aQYa5fq0nEPxtQ7g%3d|Mouser]] |end | ||
+ | |U3 U4 |2 |74LS165 |SO-16-N |595-SN74LS165ADR |[[https://www.mouser.at/ProductDetail/Texas-Instruments/SN74LS165ADR?qs=sGAEpiMZZMtsbn1GaJysl8drSYt3ukOhomiqNWJr5rc%3d|Mouser]] |end | ||
+ | |M2 |1 |µSD_DM3ATDM3AT |ΜSD_DM3AT |798-DM3AT-SF-PEJM5 |[[https://www.mouser.at/ProductDetail/798-DM3AT-SF-PEJM5|Mouser]] |end | ||
===== To Do ===== | ===== To Do ===== | ||
Line 58: | Line 90: | ||
===== Resources ===== | ===== Resources ===== | ||
+ | KiCad-Data{{:phatline:ccl-dipcore.7z|}} \\ | ||
its based on a mixture off: | its based on a mixture off: | ||
* [[http://wiki.midibox.org/doku.php?id=msq-cc-lre|msq-cc-lre]] | * [[http://wiki.midibox.org/doku.php?id=msq-cc-lre|msq-cc-lre]] |
