cc-looper [2020/03/30 00:17] phatline [Building] |
cc-looper [2020/12/24 14:14] phatline [To Do] |
Line 41: | Line 41: | ||
====== Building ====== | ====== Building ====== | ||
- | {{:phatline:CCL-sheme.png?900|}}\\ | ||
{{:phatline:CCL-pcb.png?500|}}\\ | {{:phatline:CCL-pcb.png?500|}}\\ | ||
{{:phatline:CCL-pcb-3dfront.png?500|}}\\ | {{:phatline:CCL-pcb-3dfront.png?500|}}\\ | ||
{{:phatline:CCL-PCB-Top-Part-Position.png?500|}}\\ | {{:phatline:CCL-PCB-Top-Part-Position.png?500|}}\\ | ||
{{:phatline:CCL-PCB-Back-Part-Position.png?500|}}\\ | {{:phatline:CCL-PCB-Back-Part-Position.png?500|}}\\ | ||
+ | {{:phatline:CCL-Dipcore-Pinout.png?900|}}\\ | ||
+ | {{:phatline:screenie.jpg?900|}}\\ | ||
+ | {{:phatline:ccl-6n138.jpg?900|}}\\ | ||
+ | {{:phatline:ccl-schema-proto.jpg?900|}}\\ | ||
+ | {{:phatline:ccl-schema-verbessert.jpg?900|}}\\ | ||
+ | {{:phatline:ccl-pcb-dt-led.png?500|}}\\ | ||
==== Frontpanel ==== | ==== Frontpanel ==== | ||
Line 81: | Line 87: | ||
===== To Do ===== | ===== To Do ===== | ||
- | alot, beta test, programming the firmware, housing\\ | + | a housing/case or frontplate\\ |
===== Resources ===== | ===== Resources ===== | ||
+ | KiCad-Data{{:phatline:ccl-dipcore.7z|}} \\ | ||
its based on a mixture off: | its based on a mixture off: | ||
* [[http://wiki.midibox.org/doku.php?id=msq-cc-lre|msq-cc-lre]] | * [[http://wiki.midibox.org/doku.php?id=msq-cc-lre|msq-cc-lre]] |
