===== Introduction ===== Chaos Matrix is a programmer for an Oberheim Matrix 1000 analog synthesizer built by [[http://www.midibox.org/dokuwiki/doku.php?id=jackchaos|Patrick Manderson]]. It's capable of manipulating all 126 voice parameters including 10 programmable matrix modulations buses, ramp generators, 5 point tracking generator, 3 five stage envelopes, 2 oscillators, 2 LFOs, and much more. It features edit buffer synchronization for visual feedback and inspection of all Matrix 1000 voices parameters, patch compare, patch init, advanced performance options for some parameters as well as containing all 1000 original patch names. Seeing patch names instead of numbers alone, makes it a lot easier to remember your favorites. Chaos Matrix is currently a work in progress and is nearly complete. It was built with help from the MBHP (MidiBox Hardware Project) using the MIOS operating system. It uses 1 DIN module, 1 AIN module, 1 DOUT module and 1 core with a PIC18F4620 microprocessor along with a custom application built with the C skeleton interface. Forum announcement here: [[http://www.midibox.org/forum/index.php/topic,14240.0.html]] [[http://www.flickr.com/photos/19562549@N00/4163202942/|{{http://farm3.static.flickr.com/2596/4163202942_47d93fd6f3.jpg}}]] [[http://www.youtube.com/watch?v=PJMrMQk5lrk|YouTube video demonstration.]] === Current Status (updated 20091212) ==== * The electronics need to be mounted inside the wooden enclosure. * Rear panel with MIDI & power jacks * A MIDI merge has to be built, its necessary for the edit buffer sync feature without the need of a PC. * The encoder setup isn't perfect, I still get occasional skipping. * Software 99.9% complete. ===== History ====== The project started in 2006 with a bold design: build a voice programmer for an Oberheim Matrix 1000 with a dedicated control for every parameter. Unfortunately there was a physical limit to the number of analog and digital inputs I could use with one core. So I compromised by layering groups together, like the DCO, LFO and ENV controls with select buttons. [[http://www.flickr.com/photos/19562549@N00/309416761/|{{http://farm1.static.flickr.com/105/309416761_7f34ea7447_m.jpg}}]] The prototype, containing all the surface controls was built and mounted in a pair of cardboard boxes. 90% of the software was completed and all the panel controls worked as designed. The project didn't go much beyond that for a few reasons. * The cost of manufacturing the aluminum panel, along with the engraving for each and every control (104) exceeded $450. Way too much money than I was willing to spend. * The aesthetics of all the controls on a 6u rack mountable panel was rather unattractive and and difficult to read. I also realized for a lot of controls, I rarely used them (ramps, tracking parameters, modulation switches). These were taking up valuable space on the panel and getting everything arranged neatly on the panel was difficult. * I ran out of flash storage on the PIC18F452 microprocessor and had a lot more features to code for the LCD panel and the matrix modulation parameters. This was later resolved by getting another PIC with more storage. * And finally, the compromises I made layering some of the most important parameters made sound programming non intuitive. After all my hard work, I didn't want to invest any more money and time on something that was ugly and costly and didn't work as intended. For the next few years the prototype sat in my office. Occasionally I would turn it on and play it a while. Eventually I got tired of looking at an incomplete project and decided to give it another shot. This time, sticking to the basics... keep it simple, stupud! ===== Panel Design ====== [[http://www.flickr.com/photos/19562549@N00/3986985412/|{{http://farm3.static.flickr.com/2432/3986985412_ded209ba09_m.jpg}}]] [[http://www.flickr.com/photos/19562549@N00/3988238182/|{{http://farm4.static.flickr.com/3455/3988238182_07ec1a1b82_m.jpg}}]] [[http://www.flickr.com/photos/19562549@N00/3987498979/|{{http://farm3.static.flickr.com/2552/3987498979_065e4109cd_m.jpg}}]] [[http://www.flickr.com/photos/19562549@N00/4022577298/|{{http://farm3.static.flickr.com/2567/4022577298_566f1a60ea_m.jpg}}]] The redesign of the panel began with inspiration from a few classic analog synths: The panel to the Oberheim OBX, Roland Jupiter 8 and Jupiter 6. I liked how simple the two rows of controls were laid out on the Jupiter 8 and how easy it was to see the flow of synth parameters. I knew that the Chaos Matrix would have to have no more than two rows of controls and they would have to fit in 24 inches of the "Live Panel" and the rest of the parameters would be menu driven from the "Soft Panel". === Live Panel === The most important parameters would have a dedicated control here. Note: the Matrix 1000 actually has 3 envelopes. The 1st is almost always modulating the filter cutoff, the second envelope modulated the main VCA and the 3rd was sometimes used to modulate the FM amount or the DCO pitch. I decided the 3rd envelope would be accessed through the soft panel when tweaking the preset patches. === Soft Panel === The rest of the parameters would have to be controlled from a menu driven interface using a 2x20 CLCD, 1 encoder and 8 buttons with LEDs. === LFO Section === 2 LFOs, each with a Speed and Depth potentiometer, and a button to toggle 1 of 7 waveforms. The last waveform "Sample Modulation" can further be edited on the soft panel with its rotary encoder. The speed values are also indicated by blinking the LEDs on the waveform buttons. The slower the LFO setting, the slower the blinking. === Oscillator Section === All the knobs on the Live panel are potentiometers except for DCO1 and DCO2 frequencies. The prototype originally used potentiometers but I found it difficult to dial in an exact frequency. I decided to use detented encoders instead. Pulse waveform can be enabled by toggling the pulse button and altering its shape with the "Width" knob below it. Click the pulse button a 2nd time the button blinks and any adjustments to the "Width" knob instead adjusts the pulse width modulation depth to LFO 2. DCO2 Click/Noise button is a 3 state button allowing you to enable the noise wave without needed an additional button. When noise is enabled, the LED blinks. The Sync button toggles the 4 oscillator sync modes. === Filter Section === The filter to envelope modulation modulates the cutoff frequency to envelope 1 by default when editing preset patches. If a user patch is initialized, the modulation is routed to envelope 3 instead. Some of the parameters sent as system exclusive messages causes the Matrix 1000 to hang. If you're playing notes and change some of the parameters, the notes will hold for a brief moment. Most of the hanging is overcome by simply controlling the interval of messages being transmitted over MIDI for each parameter. Most behave fine and the message can be sent at normal speed, but for others, the transmit interval was reduced in order to compensate for the hanging. The effect is ideal for slow pot movements, but for quick changes, a lot of the values in between the 1st and last movement are dropped. Despite this, the solution is better than having the Matrix 1000 hang. === Envelope Section === Instead of naming the envelopes "Envelope 1", "Envelope 2" etc... I simply named them as they are on the Oberheim OBX synthesizer. The filter envelope adjusts envelope 1 or 3 depending on which patch is being edited. ===== Panel Construction ====== Some of the panel electronics, including the LCD module have to be mounted on the underside of the panel. I used stripboards from [[http://www.futurlec.com/ProtoBoards.shtml|FutureLec]] to mount the buttons together and applied [[http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582_control_surface_construction_guide&s[]=jb&s[]=weld|Wilba's method]] of attaching countersink machine screws with JB-Weld epoxy. The epoxy has to be applied in two steps to ensure a good weld. Step one: Simply dab a bit of the epoxy on the flat head of a machine screw and place the head down on the aluminum panel (be sure to clean the panel surface thoroughly). Use a pair of clamps to provide pressure between the screw and the panel. Wait at least 24 hours to allow the epoxy to cure. Step two: Apply an additional amount of epoxy on the underside of the head of the counter-sunk screw and spread it over to the aluminum. You want to maximize the contact between the screw and aluminum surface. Allow another 24 hours to cure. [[http://www.flickr.com/photos/19562549@N00/3989235047/|{{http://farm4.static.flickr.com/3512/3989235047_4b5d1f1331_m.jpg}}]] [[http://www.flickr.com/photos/19562549@N00/3989235049/|{{http://farm4.static.flickr.com/3466/3989235049_7a09891456_m.jpg}}]] [[http://www.flickr.com/photos/19562549@N00/3989996026/|{{http://farm3.static.flickr.com/2517/3989996026_111ce7cf69_m.jpg}}]] [[http://www.flickr.com/photos/19562549@N00/3989235051/|{{http://farm4.static.flickr.com/3418/3989235051_23f56bec14_m.jpg}}]] ===== How it Works ===== Almost all communication from the Chaos Matrix to the M1000 is made via MIDI system exclusive messages. Non-registered parameter numbers were not implemented in the Matrix 1000 firmware despite what the manual states. Some communication from the M1000 to the Chaos Matrix is necessary however. === Real-Time Modulation Control === All button clicks and knob twists on the live panel send sysex voice parameter changes by default. Some parameters can optionally be adjusted by continuous controller messages directly from the front panel potentiometers, for example: When filter cutoff is adjusted via sysex, the M1000 voice processor will hang briefly when making fast sweeps from minimum to maximum. Some of the hanging is minimized by slowing the transmission interval for this parameter, but sysex messages are only necessary to set the filter if you want to store its setting in a voice patch. However for live performances where real-time tweaking is needed, a matrix modulation bus can be used to control filter cutoff using one of the available continuous controller modulation sources. Sweeping filter cutoff frequency with a continuous controller message works perfectly without hanging the voice processor. === Edit Voice Initialization === Voice parameters can be initialized to a default setting. Voice edit initialization is a good starting point to begin creating a new voice from scratch. The initialized parameters are sent to the M1000 so the display on the Chaos Matrix matches what is heard on the Oberheim. === Edit Buffer Synchronization === When selecting a new patch, the edit buffer is requested from the M1000 and processed by the Chaos Matrix, updating the status of all LEDs and parameters in the soft panel. When the edit buffer is received, you can inspect the matrix modulation, ramps and tracking generator parameters for all the patches in the M1000. When you tweak any of the live panel controls, the original value as well as the newly adjusted value is displayed. This feature requires additional MIDI cables to route the MIDI out of the M1000 back to the MIDI in of the Chaos Matrix. === Patch Compare === When making patches, the patch compare feature lets you compare your changes to the original patch. === Saving Voices === In the edit menu, select the 2nd page and select a patch location (0-199) to save your current patch. === Voice Names === The M1000 doesn't handle voice names like the Matrix 6/6R, they are simply ignored and never stored. However, each and every patch name (published when the M1000 was released) is painstakenly included in the firmware and displayed while browsing patches. The patch names make it easier to remember your favorite patches instead of going by the patch number alone.
