clock2audio2clock [2021/01/03 01:33] phatline |
clock2audio2clock [2021/01/17 01:00] phatline [Building FABRICATED PCB] |
Line 30: | Line 30: | ||
* 3x Midi-Cables\\ | * 3x Midi-Cables\\ | ||
+ | ====== Shematic ====== | ||
+ | {{:phatline:clk2a2clk-shematic.png?900|}}\\ | ||
====== Building FABRICATED PCB ====== | ====== Building FABRICATED PCB ====== | ||
Line 36: | Line 37: | ||
The Design is optimized for Pick and Place most SMD Parts are on the Back-PCB\\ | The Design is optimized for Pick and Place most SMD Parts are on the Back-PCB\\ | ||
i ordered 5 PCBs from JLCPCP with almost all SMD Parts (except Thruholes and the PTC) presoldered\\ | i ordered 5 PCBs from JLCPCP with almost all SMD Parts (except Thruholes and the PTC) presoldered\\ | ||
- | now waiting for Presoldered PCBs LOL - for 8€ a Piece!\\ | + | now waiting for Presoldered PCBs\\ |
{{:phatline:clk2a2clk-3D-top.png?500|}}\\ | {{:phatline:clk2a2clk-3D-top.png?500|}}\\ | ||
+ | arg... Jacks to near by... FIXME\\ | ||
{{:phatline:clk2a2clk-3D-back.png?500|}}\\ | {{:phatline:clk2a2clk-3D-back.png?500|}}\\ | ||
+ | ===== BOM ===== | ||
+ | ^Value^Designator^Footprint^LCSC Part Number^Library-Type^Mouser^ | ||
+ | |47uF|C1,C2,C3,C4|midibox:1206-C|C96123|basic| | ||
+ | |100nF|C5,C6,C7|midibox:1206-C|C24497|basic| | ||
+ | |220nF|C8|midibox:1206-C|C1857|basic| | ||
+ | |1N4148W|D1|midibox:SOD123-DIODE|C81598|basic| | ||
+ | |LED-Yellow|D2,D3|midibox:0603-LED|C72038|basic| | ||
+ | |BootLoad|J1|midibox:Header-1x2| | ||
+ | |Debug|J2|midibox:Header-1x2| | ||
+ | |Int.Sw|J3|midibox:Header-1x2| | ||
+ | |Header-1x3|J4|midibox:Header-1x3| | ||
+ | |Midi-DIN-5-Socket_RX|J5|midibox:Midi-DIN5-MAB5SH|||806-KCDX-5S-S2 | | ||
+ | |Midi-DIN-5-Socket_TX|J6,J7|midibox:Midi-DIN5-MAB5SH|||806-KCDX-5S-S2 | | ||
+ | |3.5Jack|J8,J9,J10|midibox:35JACK-CUI_SJ1-3535NG-PI|||490-SJ1-3535NG | | ||
+ | |CV1|JAUT1|midibox:Header-1x2| | ||
+ | |Mounting-Hole|M0,M1,M2,M3,M4|midibox:Mounting-Hole-M3| | ||
+ | |PTC|PTC1|midibox:1206-R|C126818|extended|576-1206L150THWR| | ||
+ | |4K7|Rb1,R1,R2,R3|midibox:1206-R|C17936|basic|| | ||
+ | |1K|R4|midibox:1206-R|C4410|basic|| | ||
+ | |220|R7,R8,R9,R10,R11,R12,R13,R14|midibox:1206-R|C17958|basic| | ||
+ | |10K|Ra1,Ra2,R5,R6|midibox:1206-R|C17902|basic|| | ||
+ | |100K|Rf1,Rf15|midibox:1206-R|C17900|basic|| | ||
+ | |DIPCOREF4_52P|U1|dipcore-V2C:dipCoreF4_v2c-52p-DIP-40-CMPNT_CORE_52P||@Antichambre| | ||
+ | |6N138|U2|midibox:DIP-8|||512-6N138M | | ||
+ | |MCP6002|U3|midibox:SOP-8_SOIC-8|C7377|basic| | ||
+ | |mouse-cut|cut1,cut2,cut3|midibox:mouse-cut| | ||
